Saving a graph without closing it
Is there a command line allowing me to save a graph macro without closing it?
hegedus
Dowindow/R [windowname]
/R Replaces (updates) the window macro for the named window or creates it if it does not yet exist.
jtigor
Also, Control-Y (on Windows) opens the Window Control dialog with the option to create/update the recreation macro.
peterming
hegedus wrote: Hi,
tested. this works.
Peter
peterming
jtigor wrote: Also, Control-Y (on Windows) opens the Window Control dialog with the option to create/update the recreation macro.
tested, not really saving.
Peter
jtigor
Peter
Hmmm...
If you check the "Create Window Macro" check box ("Update Window Macro" if it already exists) on the Window Control dialog, Igor will create/update the macro in the Main Procedure. You have the opportunity to specify a name for the graph window and macro with the "Window Name" text box.
Works for me, but maybe I'm missing something here. You just wanted to save the window recreation macro to the experiment, right?
JimProuty
You'll need to call DoWindow/R using an Execute/P command if you are running a procedure to save the recreation macro into a procedure window.
