Exception catching in loop -- Index Out of Range
Very basic coding question: I have a simple loop that performs an area calculation on a series of waves with a similar root name incremented by a value. There are some missing waves, however, which throw an Index Out of Range error in the middle of the loop and shut everything down. I'd like to add a line that basically says 'if this error is encountered, index+=1' and runs it again. How do I do that?
In the database I might have a collection of waves something like: Basename0, Basename1, Basename3. So, when Basename2 is used, the loop fails.
here's the code:
function AreaU()
variable numWave=40
variable index = 0
variable timeBegin = 1
variable timeEnd = 10
Make/O/N = (numWave) AreaWave
do
AreaWave[index] = area ($("Basename"+num2istr(index)) , timeBegin, timeEnd)
index += 1
while (index <= numWave)
Check for the existence of the wave before you call the area function. Use the
waveexists
function.
Like this:
function AreaU()
	variable numWave=40
	variable index = 0
	do
		WAVE/Z w = $("Basename"+num2istr(index)
		if (WaveExists(w)
			AreaWave[index] = area (w , timeBegin, timeEnd)
		index += 1
But now you have an infinite loop. How about a slightly different approach:
function AreaU()
	variable numWave=40
	variable index = 0
	String wlist = WaveList("Basename*", ";", "")
	Variable nwaves = ItemsInList(wlist)
	Variable i
	for (i = 0; i < nwaves; i++)
		WAVE w = $StringFromList(i, wlist)	// could go directly in the call to area, I find this more readable
		index += 1
