A long stringList
Hello
I have a question on the length of a string list that is valid and how can this one list be written in a multiple lines in procedure window.
I am getting the expected terminating quote error and I am guessing I exceed the maximum length allow for a string list.
How do I solve this problem? besides constructing multiple lists and splitting the original list?
jjweimer
Presuming that you are generating code, I (and others) would likely recommend a different approach than writing to a string list.
Write the code lines to a notebook.
JimProuty
If you are asking about writing code with long lines, Igor 7 has a line continuation feature:
For example:
Function foo()
	String longList="abc;def;ghi;jkl;" + \
	"mno;pqr;stu;xyz;"
	print longList
Note that each line must have an opening and closing ", so the string + operator is needed.
For more details:
DisplayHelpTopic "Line Continuation"
mwpro
jjweimer wrote: Presuming that you are generating code, I (and others) would likely recommend a different approach than writing to a string list.
May I ask how to execute the codes in a notebook? If I understand it correctly?
mwpro
JimProuty wrote: If you are asking about writing code with long lines, Igor 7 has a line continuation feature:
For example:
Function foo()
	"mno;pqr;stu;xyz;"
	print longList
For more details:
Thanks! Does Igor 6 have similar features?
jjweimer
Details are in the help topic Notebooks -> Notebooks as Worksheets
JimProuty
mwpro wrote:
Thanks! Does Igor 6 have similar [line continuation] features?
It does not, sorry.
chozo
How about the good old ...
Function foo()
	longList+="mno;pqr;stu;xyz;"
	print longList
... although I agree, that the problem should be approached differently.
