ambiguous wave point number
hello, this used to work (never mind details, edited down to bare minimum here): Function mc(B,Bphi) Wave B Variable Bphi Wave calc,B1 B1 = B / Bphi calc= - mcF(B1) return calc End It now returns "ambiguous wave point number" pointing to the B in B1 = B / Bphi. I gather things have changed in how waves are multipled by constants, so, I changed B1 from variable to wave. That moves the (same) error to "return calc". Ultimately what I want is to give the function mc a wave, B, of various values, and Bphi, a specific number, and then get back a wave after minor calculations (note mcF is defined elsewhere, and works fine). I always assumed the way this worked was IGOR implicitly took each point in B, operated on it with the variable Bphi and function mcF, and point-by-point returned the desired wave.... Any assistance navigating what is certainly a basic programming issue would be greatly appreciated! thank you---
hegedus
Hi, In the function it is expecting a single value in the return statement, but you are giving a wave. If you want to return a wave then use Function /wave mc(B,Bphi) ..... return calc end Andy
