Multiple Wave Renaming
Hi all,
is there any way to program a function to rename a number of waves?
for example: "air_SeparationXXXX", to "A_SeparationXXXX"
for XXXX= 0000, 0500
so as to avoid to rename them one by one by the Data--> Rename.. browser..
thanx,
xavier
Function RePrefixAllWaveNamesInCurrentFolder(oldprefix,newprefix)
   string oldprefix, newprefix
   string theList, theOne, theName
   variable ic, nt
   theList = WaveList("*",";","")
   nt = ItemsInList(theList)
   for (ic=0;ic<nt;ic+=1)
     theOne = StringFromList(ic,theList)
     theName = ReplaceString(oldprefix,theOne,newprefix)
     rename $theOne $theName
Thanks for your help but I couldn't finally manage. I introduced the following procedure:
Function RePrefix(air,a)
   string air, a
   variable ic, nt
   theList = WaveList("*air*",";","")
   nt = 501
     theName = ReplaceString(air,theOne,a)
After typing RePrefix(air,a) in the command line, I get the following Syntax Error: "expected string variable or string function"
Is the procedure well built? Do you have any idea of the cause of this error?
You might read the manual about string variables, in particular to understand this segement of code:
Function CreateAVacuum()
   string air, noair
   air = "air"
   noair = ReplaceString("air",air,"")
   print "This is air->" + air + "<- after loosing \"air\" ->" + noair + "<-"
xavsd wrote: Thanks for your help but I couldn't finally manage. I introduced the following procedure:
Unless air and a are global string variables, that is the cause of the error message you're getting.
Try either of the following:
String/G air = "air"
String/G a = "a"
RePrefix(air, a)
or
RePrefix("air", "a")
