Is it possible to affect radiobutton selection with DoAlert?
Hello.
I have a problem combining DoAlert and radiobuttons.
When I change between two radio button, then I want to have a question prompted which need to be answered with yes or no. If the answer is yes, then the clicked radio button should be selected. But if the answer is no, then the previous selected radio should stay selected. My current problem is when I press no than both radio buttons are selected.
Here is my code.
Function sampling_method_proc(cb):CheckboxControl
    STRUCT WMCheckboxAction &cb
    switch(cb.eventCode)
        case 2:                 // Mouse up
            sampling_method_proc_extra(cb.ctrlname)
            break
    endswitch
    PanelApp()            		//activates function for enable/disable parts of panel
Function sampling_method_proc_extra(controlname)
	 String controlname
	NVAR SamplingMethodG=root:SamplerGlobals:SamplingMethodG
	DoAlert/T="Active Checkbox" 1,"Are all Active Checkboxes unchecked?"
	if (V_flag==1)
		strswitch (controlname)
			case "sampling_automatic_panel":
			SamplingMethodG=1
			break
			case "sampling_manual_panel":
			SamplingMethodG=2
			break
		endswitch
Thank you in advance.
tony
        case 2:                 // Mouse up
            break
    endswitch
   // be careful here - PanelApp() is executed for EVERY event.
   // you should choose the events that allow execution to reach this point
     String controlname
    if (V_flag==1)
            SamplingMethodG=1
            break
            SamplingMethodG=2
            break
        endswitch
      // you arrive here when you click "no",
      // so set the global variables associated with the checkboxes as you wish
In reply to by neovenecia
tony
neovenecia wrote:
But how shall I set them that there is no change in the selection of the radio button?
you can pass the name of the checkbox that was clicked and its value from the checkbox procedure, then figure out the logic of whatever you want to do.
if g is the global variable associated with the checkbox that was clicked you will probably want to set g=!g
jtigor
Perhaps what you are looking for is the "value" keyword for the CheckBox control.  For details look up Checkbox in Command Help.
