Reverse a string
Is there a simple command to reverse a string?
String s1 = "hello"
String s2 = s1[(strlen(s1)-1) - p]
Does not work because p is only used for wave assignment. s1[4,0] doesn't work either as described in the help file. Is there a command to reverse a string that I'm missing or should just build the reversed string using a loop?
aclight
Here's an example of how to do this without a loop, though I wouldn't argue that this wins any simplicity contests:
Function test()
	String s1 = "hello"
	String s2 = ReverseString(s1)		// this works
	print s2
	s1 = "hellÖ"		// Note the umlaut on the last letter
	print s2	// This is not what you expect
Function/S ReverseString(String inputStr)
	Variable len = strlen(inputStr)
	if (numtype(len) != 0 || len < 1)
		return ""
	Make/FREE/B/U/N=(len) byteWave
	MultiThread byteWave = char2num(inputStr[p])
	Reverse byteWave
	String reversedString
	wfprintf reversedString, "%c", byteWave
	return reversedString
Note that as the test() function shows, the ReverseString function will give you what you expect if the input string contains only ASCII characters, but if the input string contains any multibyte characters you probably won't get what you expect when you reverse, since the reverse is done at the level of the bytes and not at the level of the Unicode code point or grapheme. If you needed to support reversing of strings containing non-ASCII characters I think you could do so but it would require a lot of effort.
aclight
Just for kicks, here's another way to do it. I suspect that this method is slightly faster but it relies on undocumented behavior and therefore is prone to break. Also, it requires that the length of the string be limited to a certain number of bytes. That limit could be worked around, if necessary, by putting the guts of ReverseString2 into a loop and doing the conversion from and to a structure multiple times.
Function test2()
	String s1 = "hello"
	String s2 = ReverseString2(s1)		// this works
	print s2
Constant theStringSize = 400
Structure ReverseString2Struct
	char theString[theStringSize]
EndStructure
Function/S ReverseString2(String inputStr)
		return ""
	STRUCT ReverseString2Struct s
	s.theString = inputStr
	Make/FREE/B/U tempWave
	StructPut s, tempWave
	Reverse tempWave
	Rotate strlen(inputStr), tempWave
	StructGet s, tempWave
	return s.theString
thomas_braun
Something like the following?
/// Reverse a string on a byte by byte basis
Function/S ReverseString(str)
	string str
	variable length
	length = strlen(str)
	if(length == 0)
		return str
	Make/FREE/T/N=(1, length) wv = str[length - 1 - q]
	wfprintf str, "%s", wv
	return str
In reply to by thomas_braun
aclight
    string str
    variable length
    if(length == 0)
        return str
    return str
If you're going to do this with a text wave, you should change the Make command to /T=1. Otherwise Igor will allocate an std::string on the heap for each point in the wave, and that could get moderately expensive for a long string.
sjr51
Thank you Thomas and Adam. That works great! My use case is for strings of pure ASCII and some of them might be quite long. The final function with Adam's modification works fine.
