Normalization
Hi
How do you normalize a spectre with Igor pro
johnweeks
You might want to look into the Wave Arithmetic package. To learn more about it, look at the example experiment- File->Example Experiments->Analysis->Wave Arithmetic Panel Demo.
Igor
Check out the documentation for MatrixOP which includes a number of normalization options.
tony
Depending on what you mean by normalize, this may either do what you need or give you a starting point for a GUI.
While this may seem like a lot of GUI for a trivial operation (wave/=number), I find it very useful when entering data from a lab book to be able to see and check the entries, and to be able to operate on a lot of spectra in one go.
Normalizer.ipf (5.57 KB)
In reply to by modou
tony
"Normalize a spectrum" means different things to different people.
What kind of spectrum, and how do you want to normalize it?
For example, in vibrational spectroscopy absorbance spectra collected in transmission geometry may be normalized to unit path length, or Raman spectra may be normalized to equal area, or other kinds of spectra may be normalized to a reference value at some position, there are many possibilities and we have no way to know what it is that you want to do.
tony
using trace menus:
Menu "TracePopup"
	"Normalize By Wave Max", /Q, NormaliseTraceByMax("")
Menu "AllTracesPopup"
	"Normalize All By Maxima", /Q, NormaliseAllTracesByMax()
function NormaliseAllTracesByMax()
	string tracelist=TraceNameList("",";",1+4)
	string s_trace
	variable i=0, numTraces=ItemsInList(tracelist)
	for(i=0;i<numTraces;i+=1)
		s_trace=StringFromList(i,tracelist)
		NormaliseTraceByMax(s_trace)
function NormaliseTraceByMax(s_trace, [x1, x2])
	string s_trace
	variable x1, x2
	if (strlen(s_trace)==0)
		GetLastUserMenuInfo
		string tracesList=S_traceName
	wave w=traceNameToWaveRef("",s_trace)
	if (waveexists(w)==0)
	variable maxVal=nan
	if(ParamIsDefault(x1)||ParamIsDefault(x2))
		maxVal=wavemax(w)
		maxVal=wavemax(w, x1, x2)
	duplicate /o w $nameofwave(w)+"_n" /wave=w_norm
	w_norm=w/maxVal
	printf "duplicate /o %s %s_n\r" nameofwave(w), nameofwave(w)
	printf "%s_n = %s/%g\r" nameofwave(w), nameofwave(w), maxVal
	ReplaceWave trace=$s_trace, $nameofwave(w)+"_n"
modou
If you would like to all spectre by the maximum intensity you use these scipt
    string s_trace
tony
Yes, to see the all traces popup menu you must shift-right-click on a trace in the graph window. Alternatively you can execute NormaliseAllTracesByMax() when the waves are plotted in the top graph. Or you could add another menu like this:
Menu "Macros"
	"Normalize all waves in top graph", NormaliseAllTracesByMax()
modou
Now I use this script he works
Macro GetCursor(ctrlName) : ButtonControl
String ctrlName
variable ,i_B
variable/G nn
Make/O/N=(nn) Average_Norm
                 i_A = pcsr(A)
           Average_Norm    = Average/Average[i_A]
Tony thank you for your help
