how to reverse values of every other column in a big matrix wave ?
Hello forum,
I want to reverse values of every other column in waveA, a matrix with 298 columns and 200 rows. Something like in attached image
I know for a single wave, I can use reverse command or use sort /R, but for 298x200 matrix and doing it manually for each column takes forever. So I was wondering if there is an easy way to solve this problem?
Thank you for your help.
reversing everyother column values ,
hegedus
Here is a quick solution based on 200 rows, i.e. p goes from 0 to 199.
Duplicate oldwave, newwave
NewWave = mod(q,2)? oldwave[199-p][q] : oldwave[p][q]
Logic: checks to see if column is odd, modulus=1. and then reverses the row assignment.  If even, modulus = 0, then just copies.
JimProuty
Here is a less-quick solution:
Macro ReverseOddColumns()
	String tables= WinList("*",";","WIN:2")
	String tableName= StringFromList(0,tables) // top table
	if( strlen(tableName) == 0 )
		DoAlert 0, "Expected table window"
		return
	String tblwaves= WaveList("*", ";", "MINCOLS:2,WIN:"+tableName)
	String twoDWave= StringFromList(0,tblwaves)
		DoAlert 0, "Expected two-dimensional wave in table"
		return
	ReverseColumns($twoDWave, 1, 2)
Function ReverseColumns(w, firstColToReverse, skipToNextCol)
	Wave w
	Variable firstColToReverse // 0 is the first column
	Variable skipToNextCol		// 1 to reverse all columns starting from the first, 2 to do every other one, etc.
	// Note: no input checking
	Variable ncols = DimSize(w,1)
	Variable nrows= DimSize(w,0)
	Variable wtype = WaveType(w) // 0 if text
	Make/O/N=(nrows)/Y=(wtype)/FREE columnCopy
	Variable col
	for(col=firstColToReverse; col<ncols; col+=skipToNextCol)
		columnCopy= w[p][col]
		Reverse columnCopy
		w[][col] = columnCopy[p]
In reply to by Amo
hegedus
From manual
? : is the conditional operator, which is a shorthand form of an if-else-endif statement. It is of the form:
<expression> ? <TRUE> : <FALSE>
When expression is nonzero, it evaluates the TRUE part, otherwise it evaluates the FALSE part. The ":" character in the conditional operator must always be separated with spaces from the two adjacent operands. The operands must be numeric; for strings, you must use the SelectString function.
See Operators for a list of all operators in order of precedence.
Examples
Replace zero values with blanks:
Wave w = wave0
w = w[p]==0 ? NaN : w[p]
s.r.chinn
Here is a more-quick solution:
function RevOddCols(inwave)	//	creates 'wrev'
	wave inwave
	MatrixOP/O widx = indexCols(inwave)
	MatrixOP/O wrev = inwave*equal(mod(widx,2),0) + reverseCols(inwave*mod(widx,2))
s.r.chinn
Thanks, John. I am but Grasshopper at the feet of the Master :)
Sometimes the effort of Parsing MatrixOP pays off. For the (200 row, 298 col) case cited above, the point-index method gives Profiling result for 1000 iterations:
Total time: 3.31003, Time in Function code: 3.31003 (100%)
Top function percentages:
Function Procedure RevOddColsP: 100%
Annotated Top Functions:
(Bars normalized to largest hit count)
Function: Procedure RevOddColsP; Percent total 100%
[00]          	|function RevOddColsP(inwave)
[00]          	|	wave inwave
[00]          	|
[00]          	|	variable nrows = dimsize(inwave,0)
[01]*         	|	Duplicate/O inwave, newwave
[99]**********	|	newWave = mod(q,2)? inwave[nrows-1-p][q] : inwave[p][q]
[00]          	|end
and identically-looped MatrixOP method gives
Total time: 1.63765, Time in Function code: 1.63765 (100%)
Function Procedure RevOddCols: 99%
Function: Procedure RevOddCols; Percent total 99%
[00]          	|function RevOddCols(inwave)	//	creates 'wrev'
[00]          	|	wave inwave
[04]*         	|	MatrixOP/O widx = indexCols(inwave)
[95]**********	|	MatrixOP/O wrev = inwave*equal(mod(widx,2),0) + reverseCols(inwave*mod(widx,2))
[00]          	|end
In reply to by s.r.chinn
aclight
Try adding the MultiThread keyword in front of the wave assignment statement in RevOddColsP. Depending on your processor, you might find that to be faster than the MatrixOP version. I did, with a 4 core/8 thread processor.
olelytken
This would be my approach. I used redimension to separate odd and even columns. I didn't check the speed.
Function Test()
	//	Creates a dummy wave
	Variable NumRows=200
	Variable NumCols=298
	Make/O/N=(NumRows, NumCols) root:WaveA/WAVE=WaveA
	WaveA[][]=p
	//	Adds every second column to the bottom of the previous column
	Redimension/N=(NumRows*NumCols) WaveA
	Redimension/N=(NumRows*2, NumCols/2) WaveA
	//	Makes a copy of the bottom half of the wave corresponding to the odd columns
	Duplicate/O/R=[NumRows, *][] WaveA, root:OddColumns/WAVE=OddColumns
	//	Reverses the odd columns
	Reverse /DIM=0 OddColumns
	//	Adds the odd columns back into the wave
	ImageTransform /INSI=OddColumns /INSX=(NumRows)  /INSY=0 insertImage WaveA
	//	Restores the original number of columns and rows
	Redimension/N=(NumRows, NumCols) WaveA
	//	Looks at the result
	Edit WaveA
thomas_braun
Function TimeME()
	variable now, i, numRuns = 100
	Make/FREE/R/N=(200,298) data
	data = p + q
	now = stopmstimer(-2)
	for(i = 0; i < numRuns; i += 1)
		ReverseColumns(data, 1, 2)
	printf "elaspsed %g, crc %d\r", (stopmstimer(-2) - now) / 1e6, wavecrc(0, data)
	data = p + q
		RevOddCols(data)
	data = p + q
		ReverseColumnsNew(data)
Function ReverseColumnsNew(wv)
	WAVE wv
	MAKe/N=0/FREE dest
	Reverse/DIM=1 wv/D=dest
	multithread dest[][] = mod(q, 2) == 0 ? wv[p][q] : dest[p][q]
    Wave w
    Make/FREE/N=(nrows)/Y=(wtype)/FREE columnCopy
    Variable col
        Reverse columnCopy
        multithread/NT=4 w[][col] = columnCopy[p]
    wave inwave
gives
•timeme()
  elaspsed 0.427753, crc 4151104622
  elaspsed 0.19668, crc 4151104622
  elaspsed 0.12099, crc 4151104622
So it basically depends how many cores which solution is the best. Here I'm having 12.
In reply to by olelytken
olelytken
Function Test()
    WaveA[][]=p
    Edit WaveA
A quick test on my 10-year-old computer gives 0.00014 seconds
s.r.chinn
Just to close the loop with Adam's suggesting using MultiThread (in my 4-core cpu), 1000 iterations (divide times  by 1000)
Total time: 0.996815, Time in Function code: 0.996815 (100%)
[00]          	|ThreadSafe function RevOddColsP(inwave)
[00]          	|	wave inwave
[00]          	|
[05]*         	|	Duplicate/O inwave, newwave
[95]**********	|	MultiThread newWave = mod(q,2)? inwave[nrows-1-p][q] : inwave[p][q]
[00]          	|end
and with a more efficient MatrixOp modification
Total time: 0.997383, Time in Function code: 0.997383 (100%)
Function Procedure RevOddCols: 100%
Function: Procedure RevOddCols; Percent total 100%
[00]          	|	wave inwave
[52]**********	|	MatrixOP/O widx = mod(indexCols(inwave),2)
[48]********* 	|	MatrixOP/O wrev = inwave*equal(widx,0) + reverseCols(inwave*widx)
[00]          	|end
Your mileage may vary (with number of cores, matrix dimensions, etc.)
