How to create 2D Histogram with energy units
Hi all,
I have two different energy spectrum waves (x=Counts vs y=Energy) that I want to plot. Individually, the waves have been XY paired with the correct energy scaling. I need to plot the two waves in a 2D histogram to find different characteristics at specific energies. Here is my code snippet to create a 2D histogram
function TwoDHist(X,Y, XRange, YRange, XBinNum,YBinNum, runtime, trialnum)
wave X, Y
variable XBinNum, YBinNum, XRange, YRange, runtime
String TrialNum
variable i, N=numpnts(Y), XIndex, YIndex
Make/N=(XBinNum+1,YBinNum+1)/O wave2D
for (i=0; i<N; i+=1)
XIndex = (X[i]/(XRange/XBinNum)) // divided by bin widths
YIndex = Y[i]/(YRange/YBinNum)
if ((0 < XIndex) && (XIndex < XBinNum) && (0 < YIndex) && (YIndex < YBinNum))
wave2D [XIndex][Yindex] +=1 // Add a value of 1 to specified coordinate
wave2D = wave2D/runtime //Normalize by run time
String WaveTwoD // Rename wave
WaveTwoD = "Wave2D" + Trialnum
Rename Wave2D $WaveTwoD
With this code, it will only plot counts versus counts, whereas I need to have the histogram as energy versus energy. I hope I'm not misunderstanding my own code. Thanks in advance!
Perhaps you should be using the JointHistogram operation.
But if you make a 2D histogram of two data sets with counts and energy, shouldn't the result be counts vs energy?
May 2, 2019 at 09:09 am - Permalink
I am little curious on the choice of wave names specifically X and Y since they are reserved for scaling functionality.
Would there use cause a compilation issue? Do you get the same result choosing other names?
May 2, 2019 at 09:21 am - Permalink
In reply to Perhaps you should be using… by johnweeks
I don't believe so. In my case, the X[i]/(Xrange/BinNum) is indexing the counts, which are assigned to a specific energy, and using that as the parameter to fill the 2D Histogram. I may be misunderstanding this though.
May 2, 2019 at 10:16 am - Permalink
Yes, X and Y are Igor functions to return X and Y values when used on the right-hand-side of a wave assignment. But in what was probably a historical design error, you are allowed to create variables that hide those functions. It is not good code, however, even though you will find WaveMetrics examples that use X this way.
In my first posting above, I think I misunderstood your question at the very end. I think perhaps your question is really the fact that as written, when you make an image plot using your 2D wave the axes run from [0, N-1]. But you want something that represents some range of energy. To do that, set the X and Y scaling of the 2D wave to appropriate ranges.
May 2, 2019 at 11:05 am - Permalink
In reply to I am little curious on the… by hegedus
Just changed the X and Y variables, I don't see any noticeable changes and no compilation issues. It's a good idea to stay away from those variables for wave names regardless.
May 2, 2019 at 11:12 am - Permalink
In reply to Yes, X and Y are Igor… by johnweeks
By that last sentence, do you mean going to data > change wave scaling?
May 2, 2019 at 11:19 am - Permalink
Yes. A 2D wave has two sets of scaling parameters, one for X the other for Y.
May 2, 2019 at 12:08 pm - Permalink
