Using wave elements in a Tag in a function
I have a wave named w. I have a function that takes w as an input and does a fit on it, then generates w_fit, w_coef and w_sigma.
I draw w_fit on a graph.
Now I want to write a Tag on w_fit using values from w_coef and w_sigma.
Is this right? Is there a neater way, because this feels to me like I am being clumsy.
Function fitthething(winput)
    //... a bunch of fitting stuff
    AppendtoGraph $(NameOfWave(winput)+"_fit")
	WAVE tempwave1 = $(NameOfWave(winput)+"_coef")
	WAVE tempwave2 = $(NameOfWave(winput)+"_sigma")
	VARIABLE center = tempwave1[2]
	STRING tempa
	sprintf tempa,"%0.1f",3.98486*tempwave1[3]
	STRING tempb
	sprintf tempb,"%0.1f",3.98486*tempwave2[3]
	STRING tagtext = tempa + U+00B1 + tempb
	Tag $(NameOfWave(winput)+"_fit"), center, tagtext
jjweimer
This is the general approach that I would take.
You might separate the function that does the tagging from the function that does the fitting, essentially having a DoMyFit(...) function and a TagMyFit(...) function that are called from a master function FitandShow(...). The DoMyFit function can be set to append the fit curve automatically to the graph. All you will need to do is tag that curve. Since you use NameOfWave more than once, define it as string wname = NameofWave(winput). In the same vein, define variable cf = 3.98486 and do sprintf ... cf*tempwave... for clarity.
hrodstein
When you are dealing with existing waves as in this case, it is best to create a wave reference rather than using $<string> repeatedly. This is more readable, easier to debug, and avoids repetition.
Here is how I would write your function:
Function fitthething(wInput)
	Wave wInput
	String wInputName = NameOfWave(wInput)
	String fitWaveName = wInputName + "_fit"
	Wave fitWave = $fitWaveName
	String coefWaveName = wInputName + "_coef"
	Wave coefWave = $coefWaveName
	String sigmaWaveName = wInputName + "_sigma"
	Wave sigmaWave = $sigmaWaveName
	AppendtoGraph fitWave
	VARIABLE center = coefWave[2]
	STRING tempa
	sprintf tempa,"%0.1f",3.98486*coefWave[3]
	STRING tempb
	sprintf tempb,"%0.1f",3.98486*sigmaWave[3]
	Tag fitWave, center, tagtext
When dealing with waves that may or may not exist, use Wave/Z and then WaveExists to test for the wave's existence.
If you are making a wave that may not yet exist, use Make $<string> or Make/O $<string> before making the wave reference.
I recommend, even for experienced Igor programmers who may need a reminder, reviewing this help topic:
