convert Timestamp to actual date
I need to convert an entire text wave of time recorded as follow:
"2011-08-30 19:11:00"
into a time in sec or whatever other time unit.
The quotes are part of the text recorded.
This is what i have tried so far, originally based on a code i found online, unsuccessful:
Function TextDateToDateYYYYMMDD_hhmmss(dateStr)
wave/t dateStr // In format YYYY-MM-DD hh:mm
Variable year, month, day,hour,minute,second
Variable i,dt
string inter
Make/o/n=(numpnts(dateStr)) NewWave
for (i=0;i<=numpnts(dateStr);i=+1)
inter = (datestr[i])
sscanf "%4d%*[-]%2d%*[-]%2d%*[ ] %2d%*[:] %2d%*[:]%2d" year, month, day,hour,minute,second
dt = date2secs(year, month, day ) + hour*3600+minute*60 +second
NewWave[i]=dt
return NewWave
johnweeks
Here's a function where I've abstracted just the part with sscanf:
Function test(instring)
	String instring
	sscanf instring, "\"%4d%*[-]%2d%*[-]%2d%*[ ] %2d%*[:] %2d%*[:]%2d\"", year, month, day,hour,minute,second
	return  date2secs(year, month, day ) + hour*3600+minute*60 +second
There are a couple things to note: I added instring to the beginning of the sscanf command; that's the source text. I added a comma after the format string. I added backslash-quotes at the start and end of the format string since you said the quotes are actually part of the text in the text wave.
You might be able to get LoadWave to do this directly if you use a custom date format:
DisplayHelpTopic "LoadWave"
and read the section about the /R flag.
pokeeffe
I use a function identical to johnweeks's to convert the timestamps from Campbell Scientific files into Igor date/time.
A minor tweak to the sscanf format string will permit reading sub-second values too. Change the input format for seconds from 'd' (integer) to 'f' (floating point):
	String instring
	sscanf instring, "\"%4d%*[-]%2d%*[-]%2d%*[ ] %2d%*[:] %2d%*[:]%5f\"", year, month, day,hour,minute,second
This function style is handy because you can do your conversion as a simple wave assignment.
Make/N=(numpnts(textTS))/D numericTS   // don't forget /D for time waves
numericTS = test( textTS[p] )
andyfaff
If you are not dealing with fractional seconds I would emphatically recommend NOT to use double precision numerical waves to store times.
I would store it in an unsigned 32 bit integer wave, much more suitable for storing very large integers than a double precision wave. In some cases (such as the number of ticks since system start) storing such values in a double precision wave results in undesirable truncation.
 make/u/i/o dt
Note that this approach would overflow in ~2039.
p.s. WM, when is there going to be a (signed/unsigned) 64bit integer wave?
hrodstein
I don't think that's right. 32-bit unsigned integers can store only 32-bits. Double-precision floating point has a 53-bit significand and therefore can store 53-bit integers without truncation.
According to wikipedia:
. . . any integer with absolute value less than or equal to 2^53 can be exactly represented in the double precision format.
Jakub
Dear all,
I have hit a snag. In my text wave, I have a time column in the PM/AM format (see attached pic). How can I convert it so that IGOR can recognize it and give me a proper time wave?
Thank you.
Text Wave (33.33 KB)
hrodstein
This function handles time with fractional seconds and AM/PM:
// ConvertTimeWithAMPMToSecond(timeStr)
// Examples:
//		Print ConvertTimeWithAMPMToSecond("01:50:12.47 AM")		// Prints 6612.47
//		Print Secs2Time(6612.47, 3, 2)							// Prints 01:50:12.47
//		Print ConvertTimeWithAMPMToSecond("01:50:12.47 PM")		// Prints 49812.5
//		Print Secs2Time(49812.5, 3, 2)							// Prints 13:50:12.50
Function ConvertTimeWithAMPMToSecond(timeStr)
    String timeStr
    Variable hour, minute, second
    String AMPMStr
    sscanf timeStr, "%2d%*[:]%2d%*[:]%g %s", hour, minute, second, AMPMStr
    Variable result = hour*3600 + minute*60 + second
    if (CmpStr(AMPMStr,"PM") == 0)
    	result += 43200			// 12*60*60
    return result
