convert Timestamp to actual date
"2011-08-30 19:11:00"
into a time in sec or whatever other time unit.
The quotes are part of the text recorded.
This is what i have tried so far, originally based on a code i found online, unsuccessful:
Function TextDateToDateYYYYMMDD_hhmmss(dateStr)
wave/t dateStr // In format YYYY-MM-DD hh:mm
Variable year, month, day,hour,minute,second
Variable i,dt
string inter
Make/o/n=(numpnts(dateStr)) NewWave
for (i=0;i<=numpnts(dateStr);i=+1)
inter = (datestr[i])
sscanf "%4d%*[-]%2d%*[-]%2d%*[ ] %2d%*[:] %2d%*[:]%2d" year, month, day,hour,minute,second
dt = date2secs(year, month, day ) + hour*3600+minute*60 +second
NewWave[i]=dt
return NewWave
There are a couple things to note: I added instring to the beginning of the sscanf command; that's the source text. I added a comma after the format string. I added backslash-quotes at the start and end of the format string since you said the quotes are actually part of the text in the text wave.
You might be able to get LoadWave to do this directly if you use a custom date format:
DisplayHelpTopic "LoadWave"
and read the section about the /R flag.
September 19, 2011 at 04:57 pm - Permalink
A minor tweak to the sscanf format string will permit reading sub-second values too. Change the input format for seconds from 'd' (integer) to 'f' (floating point):
This function style is handy because you can do your conversion as a simple wave assignment.
September 22, 2011 at 05:13 pm - Permalink
I would store it in an unsigned 32 bit integer wave, much more suitable for storing very large integers than a double precision wave. In some cases (such as the number of ticks since system start) storing such values in a double precision wave results in undesirable truncation.
Note that this approach would overflow in ~2039.
p.s. WM, when is there going to be a (signed/unsigned) 64bit integer wave?
September 22, 2011 at 07:44 pm - Permalink
I don't think that's right. 32-bit unsigned integers can store only 32-bits. Double-precision floating point has a 53-bit significand and therefore can store 53-bit integers without truncation.
According to wikipedia:
September 22, 2011 at 08:20 pm - Permalink
September 23, 2011 at 12:35 am - Permalink
Dear all,
I have hit a snag. In my text wave, I have a time column in the PM/AM format (see attached pic). How can I convert it so that IGOR can recognize it and give me a proper time wave?
Thank you.
August 27, 2019 at 06:59 am - Permalink
This function handles time with fractional seconds and AM/PM:
August 28, 2019 at 05:15 am - Permalink
In reply to This function handles time… by hrodstein
Thank you very much. Works well.
August 29, 2019 at 03:42 am - Permalink
