implicit loop in preemptive thread produces unexpected error in URLRequest
I suspect the explanation for this has something to do with complexities of memory management, but I'm curious.
I have a threadsafe string function that uses URLRequest.
If I write
textwave=strfunc(textwave[p])
URLRequest is unhappy and sets an error for each point of textwave. But this works without error:
for(i=0;i<numpnts(textwave);i+=1)
textwave[i]=strfunc(textwave[i])
Not sure if this is relevant but automatic threading divides the dest wave into chunks, one for each thread, so the index is all over the place compared with your loop that increments monotonically.
May 25, 2020 at 02:30 pm - Permalink
In reply to Not sure if this is relevant… by Larry Hutchinson
The indexing shouldn't matter in this case.
Hmm, now it seems to work both with implicit and actual loop. I really thought that I didn't change anything other than adding a loop... but it looks like I have to retract my comment. Debugging with print statements can get tricky!
FWIW, the error thrown by URLRequest was V_flag = 8305. I think maybe the /TIME flag for URLRequest was wrongly set. Anyhow, now the code works and has no unexpected behaviour.
May 26, 2020 at 12:31 am - Permalink
The /TIME flag is valid if the value is [0, 2147483). If you're using a variable instead of a numeric literal for the timeout, perhaps your variable got set to NaN or Inf or something else out of range.
May 26, 2020 at 08:14 am - Permalink
