Display Part of Wave in Table
Hi All,
I am running into an issue that seems like it should be simple to solve but I can't figure out.  I would like to display a portion of a wave in a table so that I may compare it with another wave.  The caveat is that I can't simply duplicate a portion of the wave because edits made in the table must be reflected in the original wave.  Let me give an example of what I mean:
Say we have two waves:
Make/O/N=5 wave1=p; Make/O/N=8 wave2 = p
The following command I would hope works, but does not, is
Edit wave1, wave2[0,5]
This would theoretically display two columns of data that are both 5 points long and if I changed the 0th point in wave2 in the table it would also change that same point in the wave.  Syntax similar to this works with AppendToGraph wave2[0,5] which is why I tried it.
Basically I am looking for a suggestion of a way to display part of a wave in a table in such a way that when edits are made in the table those edits are reflected in the original wave.  I have thought about trying to use dependent waves or hook functions to update another wave after editing a cell but have run into roadblocks there as well.
Any suggestions are welcome!
Dylan
Igor does not support that. The closest you can come is to display the wave in two separate tables which, if you want, could be subwindows in a control panel.
Given Wave1 and Wave2 (longer), with a desire to "match" the edit ranges, I might also suggest creating a function that will a) extract that portion of Wave2 desired to a new wave WaveX, b) make Wave2 dependent on WaveX, and c) show Wave1 and WaveX (extracted) side-by-side in a table. The only trick I see to overcome is making the dependency referenced on a limited wave range (I don't remember the restrictions on dependency functions well enough).
