Re-visit of Suggesting a Path name to Load Waves_General()
I am running IGOR 6.0 on a MacBookPro (Mojave) and am stymied over a particular programming issue.
I will spare you the larger details of what I am doing by way of identifying just that part of my macro that identifies the essence of my problem.
I have an Experiment residing in a folder that has multiple files (containing waves) that I want to randomly choose from (via Load wave operation) to operate-on.
In essence, suppose I have a very simple Macro that I use to load waves. It is:
Macro See_Next_Case() :
Load_Waves_General()
EndMacro
Here is what I wish to accomplish: When I double click an IGOR Experiment file, and execute my See_Next_Case macro I want to be presented with a dialog box "pointing into the folder in which that Experiment resides".
Here is the problem: The FIRST time I double click the experiment and execute this macro, indeed this macro does exactly what I want, BUT, the 2nd (and all successive times) I execute my macro (from that experiment) the Load_Waves_General dialog box now points into my Mac "Documents" folder (not the folder containing the experiment); this requires me to do additional navigation to get back to the folder in which my experiment resides!
I am sure if I add proper arguments to the Load_Waves_General() command it can be made to open into the experiment's folder every time. The problem is, I am having difficulty finding (either in my manuals, or on-line) the execution format of the Load_Waves_General() command (that lists all the execution options), nor directions as to how to accomplish what I need.
Any help would be appreciated.
Dave (IGOR Neanderthal s/n 8250)
The home path is what you need. Works in Igor 9, 8, 7, ....
December 4, 2020 at 01:55 pm - Permalink
In reply to The home path is what you… by tony
TethermanThanks Tony,
Executing:
PathInfo home
Print s_path
does indeed confirm that "s_path" specifies the proper path to where I want to browse for wave files. But, I am still unable to properly hook all this together successfully, to wit:
Specifically, I am having trouble with determining the correct syntax for the call to Load_Waves_General which will cause it to open a dialog into the specified folder.
My simple macro now looks like this:
Macro SEE_NEXT_CASE() :
PathInfo home // set s_path to desired folder
Print s_path //confirm s_path
Load_Waves_General() /P="s_path"
EndMacro
Maybe this isn't possible under IGOR 6?
Dave
December 4, 2020 at 04:45 pm - Permalink
What is the actual code in Load_Waves_General? That's what needs changing.
Just add "/P=home" to the LoadWave command it has, like this:
December 4, 2020 at 05:31 pm - Permalink
Hi Jim,
Thanks for helping in this matter. I had forgotten that Load_Wave_General was my own macro, so was viewing it as an IGOR primitive (which also explains why I couldn't seem to find any documentation by that name :-)
This is what constitutes my Load_Waves_General macro:
Macro Load_Waves_General()
Loadwave /G /L={0,0,0,0,0} /A /W
EndMacro
So, if I am understanding you correctly,
this should simply become:
Loadwave /G /L={0,0,0,0,0} /A /W /P=home
EndMacro
Dave
December 4, 2020 at 07:03 pm - Permalink
Exactly
December 4, 2020 at 08:09 pm - Permalink
In reply to Exactly by JimProuty
TethermanThanks Tony and Jim, problem solved and working like a charm (after I recovered from my "senior moment" :-).
As always, a joy to observe and be a part of the impeccable IGOR user community!
Dave (aka, Tetherman)
December 4, 2020 at 08:45 pm - Permalink
