Logistic fit of data set
I am interested in doing some logistic fits to some data. Anyone have a starting point on how to do it?
TIA
sjr51
Hi Andy, your question prompted me to dig out these FitFuncs from 8 years ago. As I remember it, the built-in logistic functions are symmetrical whereas the generalised logistic function and the Gompertz version of it can be more useful. I've not used since then though, so beware!
Steve
Function Richards(w,x) : FitFunc
	Wave w
	Variable x
	//CurveFitDialog/ Equation:
	//CurveFitDialog/ f(x) = K0+((K1-K0)/(1+K2*exp(-K3*(x-K4)))^(1/K5))
	//CurveFitDialog/ x
	//CurveFitDialog/ Coefficients 6
	//CurveFitDialog/ w[0] = K0
	//CurveFitDialog/ w[1] = K1
	//CurveFitDialog/ w[2] = K2
	//CurveFitDialog/ w[3] = K3
	//CurveFitDialog/ w[4] = K4
	//CurveFitDialog/ w[5] = K5
	return w[0]+((w[1]-w[0])/(1+w[2]*exp(-w[3]*(x-w[4])))^(1/w[5]))
Function Gompertz(w,x) : FitFunc
	Wave w
	Variable x
	//CurveFitDialog/ f(x) = K0*exp(K1*exp(K2*x))
	//CurveFitDialog/ x
	//CurveFitDialog/ Coefficients 3
	return w[0]*exp(w[1]*exp(w[2]*x))
hegedus
Hi Steve,
Thank you for the fit functions.  Curious any best practices for generating initial estimates for the parameters?
hegedus
Hi All,
Following the lead from Steve, I created the following fit function taking advantage of the builtin stats function.  To test things out I am using some sample data from JMP and I am getting a similar fit to the analysis from JMP.  I just have to rationalize the difference in the fit coefficients. Note: JMP does scatter plotting of the data for visual purposes.  I can replicate that later.
Function Logistic_fit(w,x) : FitFunc
    Wave w
    Variable x
    //CurveFitDialog/ f(x) = 1/(1+exp(-(x-a)/b))
    //CurveFitDialog/ x
    //CurveFitDialog/ Coefficients 2
    //CurveFitDialog/ w[0] = a
    //CurveFitDialog/ w[1] = b
    return statsLogisticCDF(x,w[0],w[1])
hegedus
Rationalized the differences in the coefficients.  In JMP the exponential is -(B*x -A) and IP it is -(x-a)/b and when rearranged the match to ~10% which is reasonable for an exponential fit.
