Extract selected data based on time wave
Hi, I have 3 waves:
DataWave - The data with number of points equal to number of points in TimeWave
TimeWave - The time wave of the DataWave
2ndTimeWave - A time wave to use for the selection of data, it has much more less number of points than DataWave or TimeWave
I want to create a NewDataWave from the extraction of DataWave, but employing the times from 2ndTimeWave as indexer, so then, NewDataWave will have the same number of points as 2ndTimeWave.
I hope somebody can help me, thanks in advance.
Try using the interpolate dialog. Create the four waves first, then take select the 2nd time wave as destination coordinates.
February 8, 2021 at 11:21 am - Permalink
In reply to Try using the interpolate… by tony
erickbermontThanks a lot! That worked perfectly, I would have never found interpolate2 as a solution, since in the help browser that function is described as a smoothing technique.
February 8, 2021 at 07:33 pm - Permalink
Great that your problem has been resolved. Just to avoid confusion: You may have misread the possible option to use a 'smoothing spline' for interpolation as some kind of smoothing operation. But Interpolate2 does as the name says just an interpolation, i.e., it constructs new values between a discrete set of given values. In fact, with the option /T=1 (linear interpolation) as proposed by Tony there is no smoothing done at all.
February 8, 2021 at 11:42 pm - Permalink
