user-defined curve fitting
I would like to fit my data using a specific function y=a*x/(b+x). It seems that this can only be done by programming instead of GUI, could anyone kindly provide a template or direct instruction for doing user-defined curve fitting? Thank you very much for your help!
Best,
Chu
Look in the curve fitting dialog: Analysis > Curve Fitting, for the 'New Fit Function' button.
a and b are the fit coefficients, x is the independent variable.
Click the 'Help' button (or execute DisplayHelpTopic "curve fitting") for instructions on how to set up a user defined function.
If you run into problems, ask here.
April 27, 2021 at 11:40 pm - Permalink
Check out the menu: Analysis --> Curve Fitting, then the "New Fit Function" button on the "Function and Data" tab.
DisplayHelpTopic "User-Defined Fitting Functions"
April 27, 2021 at 11:43 pm - Permalink
Good morning, Christian!
April 27, 2021 at 11:44 pm - Permalink
In reply to Check out the menu: Analysis… by ChrLie
thuzhengc12Hi everyone, thank you so much for all your advice, it has worked great to me! Thanks a lot!
Best,
Chu
April 27, 2021 at 11:58 pm - Permalink
In reply to Good morning, Christian! by tony
ChrLieHi Tony, I was a bit too late ... I think not the first time ;-)
April 28, 2021 at 11:34 pm - Permalink
