Passing more infos into PopupMenu list functions
I have a GUI with a SetVariable and a PopupMenu. The function providing the popup menu entries would need to read another GUI control for doing its job. As that is not possible, I now always have to reset the function defining the string for the popup menu.
Example:
Function/S GetList(string searchString)
	return GrepList("abcd;efgh", searchString)
FUnction Test()
	NewPanel/K=1
	SetVariable searchstring, value = _STR:".*",proc=SetVarProc
	PopupMenu pop, value=#"GetList(\".*\")"
Function SetVarProc(sva) : SetVariableControl
	STRUCT WMSetVariableAction &sva
	switch (sva.eventCode)
		case 1: // mouse up
		case 2: // Enter key
		case 3: // Live update
			PopupMenu pop, value=#("GetList(\"" + sva.sval + "\")")
			break
	endswitch
Now I would prefer if the GetList function would be passed a struct similiar to WMSetVariableAction so that it could dynamically generate the list itself. This new struct should have at least a window name and control name member.
My current approach makes the code quite complicated, and also took a non-trivial amount of time to get the quoting in the popupmenu value string right ;)
tony
If you want a function that specifically resets popupmenu lists based on setvariable actions, why not write a function that takes WMSetVariableAction as a parameter? Or are you looking for something more general?
I find getting and setting control values to be laborious in Igor. I often wish Igor had JavaScript-like window objects so that I could write something like PanelName.PopUpName.value = PanelName.SetvarName.value. Sometimes I create a structure for a panel with a substructure for each control that can be populated using a wrapper for ControlInfo like this:
static structure ControlValueStructure
	int16 type
	string ctrlName
	variable value
	string sval
	STRUCT RGBColor rgb
	STRUCT RGBAColor rgba
	variable selcol
endstructure
static function getControlValue(string win, string controlName, STRUCT ControlValueStructure &s)
	ControlInfo /W=$win $controlName
	s.ctrlName = controlName
	s.type = v_flag
	switch (abs(V_Flag))
		case 3: // popup menu
			s.rgb.red = V_Red; s.rgb.green = V_Green; s.rgb.blue = V_Blue
			s.rgba.red = V_Red; s.rgba.green = V_Green; s.rgba.blue = V_Blue
			s.rgba.alpha = V_Alpha
		case 2: // checkbox
		case 4: // valdisplay
		case 5: // SetVariable
		case 7: // slider
		case 8: // tab
			s.value = v_value
			s.sval = s_value
			break
		case 11: // listbox
			s.value = v_value
			s.sval = s_value
			s.selcol = v_selcol
			break
	endswitch
An equivalent SetControlValue() function could be useful. Then I could use ModifyControl and SetControlValue as control-type agnostic functions.
thomas_braun
Because I still would need to manually reset the value string. And I want to avoid that as it is difficult to maintain.
olelytken
Your GetList function could use ControlInfo to find the value of searchstring.
I often have two popup menus when I need the user to select a wave. One to select the datafolder to look in and one with all the waves in that datafolder. To do that the wave-selection popmenu function uses ControlInfo to find the value of the datafolder popupmenu.
I still have to update the wave-selection popup menu whenever the datafolder value is changed, just as you do with your popup call when searchstring is called, but I can get away with a simple "PopupMenu DisplayedWavePopUp mode=1, win=$PU_Struct.win" without having to change the value string every time.
thomas_braun
I don't think this will work. The name of the window is not fixed. And I also can't rely on the top window being the one holding the control as the GUI control could be called programmatically.
tony
Also (Thomas has probably already thought about this, but it's worth noting here):
If you feed a user-supplied regex to grep or greplist, you need to consider what happens in the event of a regex error.
try..catch..endtry is one way to deal with runtime errors.
In reply to by thomas_braun
tony
Use a global string?
... I'll get my coat.
olelytken
If both controls are in the same window you use $PU_Struct.win as the window name. Otherwise you will have to pass the name through the PopupMenu value=#"GetList(\".*\")" call, as a parameter for GetList.
EDIT
I guess the window name of the control cannot be accessed inside of GetList so you will have to pass it along through the value=#GetList call
olelytken
value=#("EccentricXPS#XPSViewPopUpWaveList(2, \""+SubWindow+"\", \"DataFolderPopUp\")")
This is a quick copy-and-paste from one of my programs. It passes the window name (the variable SubWindow) along as well as the name of the control (the string value "DataFolderPopUp") to run ControlInfo on
thomas_braun
Just to clarify: I do have a solution which works already. I just think it is too complicated to use and would like to have a more straightforward solution.
Multiple windows with multiple controls. So nope.
thomas_braun
Yes, good code does that. Mine here is a MWE.
In reply to by olelytken
tony
olelytken wrote: It passes the window name (the variable SubWindow) along as well as the name of the control (the string value "DataFolderPopUp") to run ControlInfo on
olelytken's solution works, no? you must know the host window name and the corresponding setvar when you create the popup, so just hardwire the names into the GetList function call and run ControlInfo from GetList?
thomas_braun
Yes it works in principle. But unfortunately in my case the window name is getting renamed occasionally. (Yes this was a dump thing to do in the first place, but that is how it is.)
