Scale Problem
I have the following problem...
2 waves... same X. (same duration), but different number of points. and i need to do the sum of both, i try w3[x]=w1[x]+w2[x], w1 and w2 whit different number of points but.. not result.
any idea?
thanks.
I don't understand what you are trying to do. It is not clear what you are trying to sum.
Perhaps this example will help you:
Make/O/N=10 w1 = p; SetScale/P x 0, .1, "s", w1
Make/O/N=11 w2 = p; SetScale/P x 0, .1, "s", w2
Make/O/N=10 w3; SetScale/P x 0, .1, "s", w3;
Edit w1, w2, w3
w3 = w1(x) + w2(x)
To understand the meaning of x on the righthand side of the assignment statement, execute this command:
and read that help topic.
problem solved.... i was trying to sum two waves whit distint number of points, the solution, i do a curvefit of one of my waves whit the fitcurve having the number of points of the second wave, now i can the operation whitout problems..
thanks for the help hrodstein
purozongo wrote: problem solved.... the solution, i do a curvefit of one of my waves ...
See this Code Snippet for a function that also might solve your problem.
