Molar weight calculator
//EDIT: 2/23/16; optimised function "ElementCount"
// The function molwt(str) returns the molar weight of a chemical formula specified by "str", e.g. molwt("H2O") returns 18.0148 (in grams per mole).
// The function is case-sensitive, e.g. molwt("h2o") will not return what you expect.
// The function ElementCount(input) returns a list of elements and their abundance, e.g. ElementCount("H2O") returns "H;2;O;1;"
// The element abundance in the input string MUST be a positive integer
function molwt(str)
	string str
	variable mw
	variable AN
	variable weight
	variable n
	variable i
	string List = ElementCount(str)
	string Element =""
	//initialise elements and atomic weights: list index equals atomic number
	string el=""
	el += ";H;He;Li;Be;B;C;N;O;F;Ne;Na;Mg;Al;Si;P;S;Cl;Ar;"
	el += "K;Ca;Sc;Ti;V;Cr;Mn;Fe;Co;Ni;Cu;Zn;Ga;Ge;As;Se;Br;Kr;"
	el += "Rb;Sr;Y;Zr;Nb;Mo;Tc;Ru;Rh;Pd;Ag;Cd;In;Sn;Sb;Te;I;Xe;"
	el += "Cs;Ba;La;Ce;Pr;Nd;Pm;Sm;Eu;Gd;Tb;Dy;Ho;Er;Tm;Yb;Lu;"
	el += "Hf;Ta;W;Re;Os;Ir;Pt;Au;Hg;Tl;Pb;Bi;Po;At;Rn;"
	el += "Fr;Ra;Ac;Th;Pa;U;Np;Pu;"
	string aw=""
	aw+=";1.0079;4.0026;6.941;9.0122;10.811;12.011;14.007;15.999;18.998;20.18;22.99;24.305;26.982;28.085;30.974;32.065;35.453;39.948;"
	aw+="39.098;40.078;44.956;47.867;50.941;51.996;54.938;55.845;58.933;58.693;63.546;65.409;69.723;72.64;74.922;78.96;79.904;83.798;"
	aw+="85.468;87.62;88.906;91.224;92.906;95.94;98.906;101.07;102.91;106.42;107.87;112.41;114.82;118.71;121.76;127.6;126.9;131.29;"
	aw+="132.91;137.33;138.91;140.12;140.91;144.24;146.92;150.36;151.96;157.25;158.93;162.5;164.93;167.26;168.93;173.04;174.97;"
	aw+="178.49;180.95;183.84;186.21;190.23;192.22;195.08;196.97;200.59;204.38;207.2;208.98;208.98;209.99;222.02;223.02;"
	aw+="226.03;227.03;232.04;231.04;238.03;237.05;244.06;"
	do
		Element = StringFromList(i, List)
		if ( strlen(Element) == 0)
			break
		AN = WhichListItem(Element, el)
		weight = str2num(StringFromList(AN, aw))
		n =  str2num(StringFromList(i+1, List))
		mw += (n * weight)
		i+=2
	while(1)
	return mw
function/S ElementCount(input)  // analyses input string for elements and number of elements
	String input
	string list = ""
	variable i
	variable TheEnd = StrLen(input)
	for(i=0;i<TheEnd; i+=1)
		// consider cases where string item is a letter and upper case
		if (GrepString( input[i], "[[:alpha:]]")  &&  GrepString(input[i], "[[:upper:]]") )
				list += input[i]
				// is it a two character element, e.g. Fe instead of F?
				if (GrepString(input[i+1], "[[:alpha:]]")  && GrepString(input[i+1], "[[:lower:]]") )
					list +=  input[i+1]
					i+=1
 				//this element is covered
 				list +=";"
				// test if next list item is numeric or string; if it is string, then the present element has a count of 1, add this to list ....
				// ...or check if i+1 is the last entry
				if (GrepString(input[i+1], "[[:alpha:]]") || i+1 == TheEnd)
					list += "1;"
				// we are done
				continue
		// consider cases where string item is a number
		if (GrepString(input[i], "[[:digit:]]") )
				list +=input[i]
				// is there more than one numeric character?
				do
					if (GrepString(input[i+1] "[[:digit:]]"))
						list += input[i+1]
						i+=1
						break
				while(1)
				List +=";"
	return list
I have one of these too. Not tested for typos etc, so caveat emptor!
Edit: I removed the code and added a link to the molar mass calculator project below.
Building on ChrLie's and Tony's code, I slightly enhanced the ElementCount function to deal with non-integer Stoichiometry and only parse actual element names
function/S ElementCountMM(input)  // analyses input string for elements and number of elements //adapted from the wavemetricsForum
//works with non-integer stoichiometry
    String input
    string list = ""
    variable i,ii
    string dum
	make /free /n=0 /T Elem
	Elem = {"H","He","Li","Be","B","C","N","O","F","Ne"}
	Elem[10] = {"Na","Mg","Al","Si","P","S","Cl","Ar","K","Ca"}
	Elem[20] = {"Sc","Ti","V","Cr","Mn","Fe","Co","Ni","Cu","Zn"}
	Elem[30] = {"Ga","Ge","As","Se","Br","Kr","Rb","Sr","Y","Zr"}
	Elem[40] = {"Nb","Mo","Tc","Ru","Rh","Pd","Ag","Cd","In","Sn"}
	Elem[50] = {"Sb","Te","I","Xe","Cs","Ba","La","Ce","Pr","Nd"}
	Elem[60] = {"Pm","Sm","Eu","Gd","Tb","Dy","Ho","Er","Tm","Yb"}
	Elem[70] = {"Lu","Hf","Ta","W","Re","Os","Ir","Pt","Au","Hg"}
	Elem[80] = {"Tl","Pb","Bi","Po","At","Rn","Fr","Ra","Ac","Th"}
	Elem[90] = {"Pa","U","Np","Pu","Am","Cm","Bk","Cf","Es","Fm"}
	Elem[100] = {"Md","No","Lr","Rf","Db","Sg","Bh","Hs","Mt","Ds"}
	Elem[110] = {"Rg","Cn","Uut","Fl","Uup","Lv","Uus","Uuo"}
			list += input[i]
				list +=  input[i+1]
				i+=1
			list +=";"
				list += "1;"
				FindValue /TEXT=StringFromList(itemsinList(list)-2,list)/TXOP=7 /Z  Elem
				if (v_value==-1)
					list="" ; i=TheEnd ;Print "Could not resolve Chemical Formula";beep;beep;dowindow/h
			continue
		if( grepstring(input[i],"[0-9]") )
			dum=""
			do
				if( grepstring(input[i],"[0-9\.]"))
					dum+=input[i]
					i+=1
					break
			while(i<strlen(input))
			i-=1;
			list +=  dum+";"
			list+=";"
	return list
My version was later released as a project, here. I believe it deals with both non-integer values and parentheses properly, and only accepts valid elements.
•print molWt("(Mg0.9Fe0.1)2SiO4")
  147.001
I see. You might consider using a key list, then you can use NumberByKey to get the element count.
Execute DisplayHelpTopic "NumberByKey" for more info.
