Image Graph not updating on base data load and overwrite
Fri, 11/12/2021 - 01:00 pm
I have an image analysis experiment and as part of the automation scheme, I have a singular wave that holds the image and when I load a new image that wave gets overwritten to preserve the wave name in the procedure.
So I have wave cleverly called image and have it displayed in a graph window. I then load a new wave, manually at present, and select the same name and highlight the overwrite checkbox. The image loads but the display of the image still retains the previous input. I run a function that calls that wave and does some functions and returns some data. After that has run, the display in the original graph now shows the newly loaded data.
Variable num_pads,index,pointcount
//Find the roi of for background and for pad arrays
//fill in gaps between
NewdataFolder/O/S Temp
ImageMorphology /i=5/E=5 Erosion imagein
Wave IM = M_ImageMorph
Wave M_imagethresh
//generate a background curve
Extract/FREE imagein, Backgroundtemp, M_imagethresh==255
Make/O/N=256 background
histogram/CUM/B=2 backgroundtemp,background
pointcount=numpnts(Backgroundtemp)
background /=pointcount
find_Pads_stats(IM)
//Find Pad Centers
wave W_xmax,w_xmin,W_ymax,W_ymin
num_pads=numpnts(W_xmax)
make/O/N=(num_pads,2) centers
setlabels("x;y",centers,1)
centers[][%x]=(w_xmax[p]+w_xmin[p])/2
centers[][%y]=(w_ymax[p]+w_ymin[p])/2
for(index=0;index<num_pads;index+=1)
find_pads_mark(IM,centers[index][%x],centers[index][%y])
wave M_particlemarker
Extract imagein, padtemp, M_particlemarker==0
make/O/N=256 $("pad_"+num2str(index))
wave pad=$("pad_"+num2str(index))
histogram/CUM/B=2 padtemp,pad
pointcount=numpnts(padtemp)
pad /=pointcount
setdataFolder root:
It was my understanding that the original graph would have been updated automatically to reflect the new underlying upon load. Am I mistaken? I am using IP Version: 9.00 (Build 37840) on a Mac OS X 11.6 (Big Sur). The example in the image shows the effect. I have loaded new data and you can see it in the preview pane in data browser. The large graph with is displaying that same wave, but it has the data from the previous wave.
Andy,
It is difficult to tell you what is going on other than starting from the observation that some of the displayed waves belong to the private data folder (you should make copies elsewhere). It is also possible that you are displaying an image of a wave that is in the private data folder. In general, it is clear which wave is displayed in the Data Browser while it may not be obvious about graph windows.
AG
November 12, 2021 at 02:08 pm - Permalink
Doesn't that just look like that ImageLoad does not mark existing waves as modified when it has written into it?
November 12, 2021 at 02:47 pm - Permalink
Here is the window recreation macro for the graph. Pretty simple stuff. It is pullng waves from two places the root where the image is and the temp folder I create for organizational neatness.
PauseUpdate; Silent 1 // building window...
String fldrSav0= GetDataFolder(1)
SetDataFolder root:Temp:
Display /W=(689,53,1949,1109)/T W_BoundaryY vs W_BoundaryX
AppendImage/T ::image
ModifyImage image ctab= {*,*,Grays,0}
SetDataFolder fldrSav0
ModifyGraph margin(left)=14,margin(bottom)=14,margin(top)=14,margin(right)=14
ModifyGraph mirror=2
ModifyGraph nticks(left)=19,nticks(top)=22
ModifyGraph minor=1
ModifyGraph fSize=9
ModifyGraph standoff=0
ModifyGraph tkLblRot(left)=90
ModifyGraph btLen=3
ModifyGraph tlOffset=-2
SetAxis/A/R left
EndMacro
November 12, 2021 at 03:22 pm - Permalink
It seems that Thomas is correct; the RPNG is not marking the wave as modified. A simple workaround for Andy is to execute a DoUpdate after loading the new image. This will be fixed for the next build.
AG
November 12, 2021 at 03:47 pm - Permalink
Or a simple non-modifying modification to the wave: image += 0
November 12, 2021 at 04:21 pm - Permalink
In reply to It seems that Thomas is… by Igor
Doupdate is not a workaround. The image still does not update. Just FYI.
November 13, 2021 at 12:50 pm - Permalink
Andy,
Right. DoUpdate checks to see if the wave is marked as modified. Have you tried the nightly build?
AG
November 13, 2021 at 04:16 pm - Permalink
In reply to Andy, Right. DoUpdate… by Igor
I did just try it and (drum roll please) - It works as expected. You guys are the best.
November 13, 2021 at 05:13 pm - Permalink
