Modifying drawtext object
Hello. I am making a user interface using an Igor's panel and would like the program to display a few lines of message about data processing step to the users. I have used SetVar with global string and it works fine for short messages, but for long multi-line message, I still cannot find a good way to do it in the panel. I understand that TextBox inside Graphs can be used for that, but is there any equivalent textbox that I can put in the panel to display multi-line texts? DrawText works almost fine but what is the best way to modify the displayed text? Do I need to store the object index to delete and draw a new one everytime? I attached the images of the panel that I'm working on.
Thank you very much
Best wishes
The object from DrawText The panel
For a simple multiline text: Use a TitleBox where the message is the title. Use \r to break the line here. To replace the text just call the TitleBox again with the new title= setting.
For doing advanced stuff with all bells and whistles: Embed a notebook subwindow, where you could even display a complete manual with formatting. You can use the Notebook command to modify the contents, but it is more involved of course.
In reply to by chozo
Thank you very much, Chozo. I never thought about adding NoteBook subwindows to a panel. I find that interesting and will explore more about NoteBook programming. TitleBox almost works except that it can only display a limited number of characters.
If you use Titlebox title="a string", then the number of characters is limited. If you use the variable keyword instead of title, you can have more text:
•String tbtext="This is one line of text"
•newpanel
•ShowTools/A arrow
•TitleBox title0 variable=tbtext,pos={23,17}
•tbtext += "\rThis is another line of text"
•tbtext += "\rThis is yet another line of text"
•tbtext += "\rAnd yet another line of text"
