How do I write (append) a string to a file?
I would like to a open a file and append some strings to it. What is the command to open a file and write a String to it? Is it possible to keep the file open and write several string sequentially? Or is it possible to just open a file for appending a string?
johnweeks
Function/S CreateAFile()
	Variable refnum
	Open refnum
	if (refnum)
		fprintf refnum, "pi = %g\r", pi
	FStatus refnum
	String filepath = S_path+S_fileName
	Close refnum
	return filepath
Function AddToFile(String filepath)
	Variable refnum
	Open/A refnum as filepath
	if (refnum)
		fprintf refnum, "e = %g\r", e
	Close refnum
Function Test()
	String fpath = CreateAFile()
	AddToFile(fpath)
The first function creates a new file, writes one line into it, and returns the full path to that file. The second function takes in a string containing a full path to a file, and adds a line to that file. The function test() calls both of those functions in sequence to create a file with two lines.
Clearly an inefficient way to make a two-line file! But it does illustrate the technique. When you invoke test(), a dialog is put up asking you to give a name to the file and choose a location for it. The function should complete without asking you for more information, since the full path to the file is returned from CreateAFile().
thomas_braun
The background is that an open file has a read/write position associated with it in Igor Pro. You can query the file position via FStatus. And also set it via FSetPos. And by using Open/A that file position is set to the end internally, whereas Open just leaves it at the start.
chozo
I would say that if you want to write a string to a text file, fprintf is your best option. Just do 'fprintf refnum, mystring' and you should be good to go. I don't know if there is an intrinsic character limit, but I see no problem to 'dump' an entire string. And even if there was a character limit, its just a matter of splitting up the string into parts.
