Using Grep to filter a text wave
I have a text wave (txtwave) containing a list of formulas. The formulas have CHNO elements in them but some formulas have only CHO elements. I want to extract formulas (with their index numbers) that have only CHNO vs formulas that have only CHO. I have been using Grep/INDX/Q/E to extract things that contain something but I don't know whether there is a way to use Grep to exclude things that contain something while listing the remaining.
For example: I can do Grep/INDX/Q/E="N" txtwave  and it will give me W_Index for all formulas containing CHNO.
However, how can I extract formulas that do not contain N?
Sincerely,
Peeyush
chozo
Here is a snippet from the Grep help:
/E={regExprStr, reverse }
Specifies the Perl-compatible regular expression string, regExprStr, for which the sense of the match can be changed by reverse.
reverse=1:	Matching expressions are taken to not match, and vice versa. For example, use /E={"CheckBox",1} to list all lines that do not contain "CheckBox".
reverse=0:	Same as just /E=regExptrStr.
and
To copy lines that do not match the regular expression, set the /E flag's reverse parameter:
// Copy lines that do NOT contain "Fred", "fred", "fREd", etc
Grep/P=myPath/E={"(?i)fred",1} "afile.txt" as "NotFredFile.txt"
Peeyush Khare
wow this is super cool! Thanks a lot, chozo! While we are at this, is there a way to set two parameters? So, if I want to say exclude everything that contains "N" and "O" both, is there a one-liner for this? I tried Grep/INDX/Q/E={"N","O",1} txtwave but this doesn't work..
Also, just for my understanding, when I write Grep/INDX/Q/E="N" txtwave, that's just the short form of saying Grep/INDX/Q/E={"N",0} txtwave. Is this correct? that there is no logical difference between the two statements
In reply to by Peeyush Khare
tony
With grep the answer is pretty much always yes. My starting point is usually to search the web for 'regex' together with whatever I want to do. There are a lot of resources out there, regex testing engines and discussion boards filled with regex questions and answers. I strongly encourage taking a moment to look there as a first point of call when you have a regular expression question.
Note that you can use multiple regex flags with grep.
"N.*O|O.*N" is one way to say match both O and N.
