FITTING WITH TWO FUNCTION AT ONE TIME?
I'm pretty new to Igor and I think I have no talent in coding at all...... So pls help.
my question like this, I have set of intensity I(q) and q data , what I want to so is fit the data to a new function which composed of powerlaw and gaussian function. see attached file. where the I0 is the peak height, q0 is the mean postion, B is the width of the peak.
is there sb can let me know how can I do this in Igor?
data.pxp (12.85 KB)
amyAUS wrote: amy one can help,Please.......thanks
(assuming your data are already loaded as Iwave and qwave)
  • open the Analysis:Curve Fitting menu
  • select Iwave as the y data and qwave as the x data
  • click on New Fit Function
  • enter a name
  • enter parameters that you want to fit --- EXAMPLE: a, b, c
  • define the independent parameter --- EXAMPLE: x
  • write the equation for your function in the space given -- EXAMPLE: f(x) = a*x + b*x^2 + c*log(x)
  • save the fit function
  • click the coefficients tab
  • provide some initial values for the coefficients
  • click the Do It button
  • HTH
I used the Multipeak Fit 2 package (Analysis->Packages->Multipeak Fit 2) to fit your data. I didn't use the equation you included in your first post, which is just a power law plus a Gaussian peak. Your data are not symmetrical- it is hard to see how they would fit a Gaussian peak shape.
At any rate, I used two exponentially-modifed Gaussian peaks to fit your data. I have added a picture of the result to this post.
I should also note that I fitted a somewhat restricted portion of your data; I don't think that's important. I also used a linear background function. A constant background worked very nearly identically.
