Double horizontal axis (top/bottom) with different scale
I have three waves: Intensity, Time and Temperature. All waves have the same amount of points.
I would like to plot Intensity VS Time, where time is on the bottom axis, and then add a top axis
with the Temperature scale. The idea is that if, for example, Time 1000 correspond to Temperature 100,
than 100 have to be exactly on top of 1000 in the graph.
I tried adding the intensity vs time (bottom axis) and then intensity vs temperature (top axis), but
the curves do not overlap. I don't understand exactly why.
It seems it should be pretty straightforward, but I have been struggling to get the result I want.
Any suggestion?
Cheers,
Fabrizio
Could you post an Igor experiment file containing your data?
January 24, 2014 at 09:14 am - Permalink
The temperature is not a strictly linear function of time.
Here's an experiment file.
Thanks
Fabrizio
January 28, 2014 at 10:54 am - Permalink
BUT there is a solution. You can use the Transform Axis package to make a mirror axis that displays ticks that are a function of the ticks on the axis it mirrors. And I have just written a transformation function that uses a wave as the source of the transformation function.
The learn more about Transform Axis, select File->Example Experiments->Graphing Techniques->Transform Axis Demo.
The package can be tricky to understand, I strongly encourage you to look at the demo.
I have attached a modified version of your experiment file that uses Transform Axis to put a Temperature top axis on a graph of Intensity vs Times. To do that, I took these steps:
0) I wrote the function TransAx_fromWave() in the main Procedure window.
1) I made the graph of Intensity vs Times.
2) From the Graph menu, I chose Packages->Transform Axes
3) From the Graph menu, I chose Transform Axis->Transform Axis.
4) In the control panel, I selected these settings:
Function: fromWave
Axis: Bottom
Turned on the Make It a Mirror Axis checkbox
Selected Temperature as the Coefficient wave
5) Click Do It.
January 28, 2014 at 09:57 am - Permalink
Thanks a lot,
Fabrizio
January 28, 2014 at 10:56 am - Permalink
I thought I'd post a question here seeing as this seems related to the problem I am attempting to tackle. Would you be able to help me out?
I have a graph of current density (y axis, left) which is a function of potential (x axis, bottom), but not linear. What I have been trying to figure out is how to plot time on the x axis (top).
The time is a linear function of the potential (as the potential is stepped at set time intervals).
I have been trying to see if this transform axis will do the trick, but cannot seem to get it to work. I have tried creating a wave with the time in correct intervals, but of course, I cannot plot potential vs time both on the horizontal axes alongside current density on the y axis. As Fabrizio said; it seems as though this would be a simple solution, but in fact it is not!
The attachment is a screenshot of the graph; ideally I would like to plot the time on the top axis.
Can you help?
August 5, 2014 at 08:34 am - Permalink
Can you help?[/quote]
If you attach the entire experiment, then perhaps we can see what's going wrong.
August 5, 2014 at 10:49 am - Permalink
Replace "1.8" and "32" with the appropriate factors for your transformation. And give the function a new name; it MUST start with "TransAx_".
August 7, 2014 at 01:39 pm - Permalink
In reply to by johnweeks
UPDATE!
I found the "TransAx_fromWave" using the procedure browser.
Dear John,
I want to use the option "TransAx_fromWave" option. I assume this is not available on the standard Transform graph package.
I can't figure out from the TextJW.pxp file where you changed the procedure.
I would highly appreciate it if you could help me out.
Greetings,
Siva
July 9, 2022 at 04:39 am - Permalink
Hi Everybody,
I am dealing with the same issue as that discussed in this post. Specifically, I would like to add a secondary, non-linear, horizontal axis to a graph. However, I found the Transform Axis package to be confusing and therefore I would like to avoid using it. I considered ways to sidestep this procedure such as that described in the "Transform axis help" post but the function included in this second post seems to be more complicated than what I need. Ultimately, the solution I settled on is to generate a new free axis and to define custom labels and ticks to be implemented for this axis using the "User ticks from waves" option. Unfortunately, I ran into a problem I do not how how to solve. This issue is illustrated by the test code presented below which generates a secondary horizontal axis and the corresponding custom labels and ticks position. The problem is that the secondary ticks and labels are not actually displayed.
I would appreciate any suggestions and comments on how to display the ticks and labels of the secondary horizontal axis.
Best,
Sebastian
November 19, 2022 at 07:02 am - Permalink
I am not sure why TransformAxis fails for your case. In the meantime, here is the modified function that you need.
November 20, 2022 at 07:43 am - Permalink
Maybe if you could elaborate a bit more why TransformAxis is problematic we could point you in the right direction. Which version you are using by the way? The package got quite a bit more convenient with Igor 9.
November 21, 2022 at 07:01 am - Permalink
In reply to Maybe if you could elaborate… by chozo
[quote=chozo]
[/quote]
Thanks to chozo's efforts!
November 21, 2022 at 04:27 pm - Permalink
Your Generate_Test_Plot() fails to do what you need because the axis range for the truly free axis is not set. You have two options:
1) Set it to a fixed range:
SetAxis g_effective 0,102) Set the axis master to the bottom axis:
ModifyFreeAxis g_effective, master=bottomOption 2 is probably the best, as it will cause your axis to follow the range of the bottom axis if it changes.
November 21, 2022 at 04:37 pm - Permalink
By the way, that's exactly what TransformAxis does. But TransformAxis tries to do it for any arbitrary transformation, which is really hard. And to make the general case a little more tractable, it doesn't handle infinities gracefully. The problem is that the inverse of your transformation is required to do the tick-spacing and nice-number computations. Singular functions are hard to deal with!
November 21, 2022 at 04:40 pm - Permalink
Hi Everybody,
Thank you so much for your replies. Your combined insight and detailed explanations have helped me to better understand and troubleshoot my code. Regarding chozo's question about the Transform Axis, as far I know there is nothing wrong with this procedure. I just did not study the documentation enough to be able to use it properly.
Best,
S
November 27, 2022 at 12:41 am - Permalink
And as I mentioned previously, your particular transformation probably doesn't work with TransformAxis due to the need to include infinity.
November 28, 2022 at 10:08 am - Permalink
