Offset wave by first value
I'm trying to zero out a 1D wave by offsetting all of the elements by the first value of the wave.  I've tried a bunch of things and they all only change the first value.  Below are a few of the commands I've tried.  I feel like I'm missing something. Is the problem that after zeroing the first value it's subtracting zero from the rest of the elements?  I'm looking for something I can run from the command line, not something I'd put in a macro or function.
Make/N=10/D test_wave=5
test_wave = test_wave - test_wave[0]
test_wave = test_wave[p] - test_wave[0]
hrodstein
test_wave[0] is changed the first time through the loop and therefore is 0 for iterations 1 through 4.
For details execute:
DisplayHelpTopic "Don't Use the Destination Wave as a Source Wave"
hegedus
Create a variable that holds the first value.
Variable offset = test_wave[0]
test_wave -= offset
