How to properly do matrix exponents?
    I have a matrix A that I want to take to the y power. Doing A^y or matrixop Out=powC(A,y) are not giving me the right answer.
However, if I manually do the matrix multiplication with:
MatrixOp Out=A x A x A x A.....
I get the right answer. However this method is infeasible for large y (I am trying to do up to y=50000). What command do I need to use to get me the correct answer without manually typing this.
chozo
You probably have picked the wrong command. Use powR instead of powC; the latter is for complex values. Does it work then? Otherwise, can you explain in a bit more detail what is 'wrong'?
s.r.chinn
displayhelptopic "MatrixEigenV"
Have you tried using MatrixEigenV? Once you have the diagonal eigenvalues, raise each to the desired power, then re-transform with the left and right eigenvector matrices.
chozo
I see your point now. powC / powR does indeed seem to do only scalar multiplication. I have no idea if there is a command for proper repeated matrix multiplication. Maybe someone else knows. By the way, I find a factor of 50000 also a bit extreme. What is your use case here?
s.r.chinn
Here is a snippet of a working example using MatrixEigenV. A caveat is that I have tested it only with a small Hermitian matrix. The example uses a power of 8 for demonstration. Note the use of powC( ) on the eigenvalues. (IP 8.04, Win10). In principle, after diagonalization, the entire power operation could be written in one MatrixOP line.
function bar()
 Make/D/N=(2,2)/O/C H={{cmplx(3,0),cmplx(2,-1)} , {cmplx(2,1),cmplx(4,0)}} // Hermitian
 MatrixEigenV/R/C H		// here is the core of the algorithm
 Wave W_eigenvalues, M_R_eigenVectors	// created by MatrixEigenV
 MatrixOP/O/C MdiagH = diagonal(W_eigenvalues) // square matrix
 MatrixOP/O/C prodH = M_R_eigenVectors x (MdiagH x inv(M_R_eigenVectors))) // checks with H
 MatrixOP/O/C HprodH     = H x H x H x H x H x H x H x H
 MatrixOP/O/C HprodHdiag = powC(W_eigenvalues,8)	//	EIGENVALUES raised to power
 MatrixOP/O/C MdiagHprod = diagonal(HprodHdiag)
 MatrixOP/O/C prodHpwr = M_R_eigenVectors x (MdiagHprod x inv(M_R_eigenVectors))) //checks with HprodH
In reply to by sleepingawake86
Igor
s.r.chinn posted the proper way to calculate the power.
sleepingawake86 wrote:
For some reason powC and ^ are not doing the expected matrix multiplication.
Powc() PowR() work on (matrix) element-by-element basis.  This is NOT matrix multiplication.  Try, for example:
Make/O/N=(2,2) ddd=2
Make/O/N=(2,2) yyy={{1,2},{3,4}}
Matrixop/o/p=1 aa=powr(ddd,yyy)
  aa[0]={2,4,8,16}
s.r.chinn
It seems to me that one plausible scenario for expanding to a power of 50000 is that the matrix is unitary. Then the magnitude of the determinant must equal 1, and each eigenvalue is of the form exp( i lambda), also magnitude 1. This type of matrix can be thought of as a generalized rotation. If the matrix is not unitary, I don't see how numeric overflow or underflow can be avoided for arbitrarily large powers.
