How to properly do matrix exponents?
I have a matrix A that I want to take to the y power. Doing A^y or matrixop Out=powC(A,y) are not giving me the right answer.
However, if I manually do the matrix multiplication with:
MatrixOp Out=A x A x A x A.....
I get the right answer. However this method is infeasible for large y (I am trying to do up to y=50000). What command do I need to use to get me the correct answer without manually typing this.
You probably have picked the wrong command. Use powR instead of powC; the latter is for complex values. Does it work then? Otherwise, can you explain in a bit more detail what is 'wrong'?
November 2, 2022 at 06:14 am - Permalink
Have you tried using MatrixEigenV? Once you have the diagonal eigenvalues, raise each to the desired power, then re-transform with the left and right eigenvector matrices.
November 2, 2022 at 06:19 am - Permalink
50000? Is that even feasible in double precision? I'm curious...
November 2, 2022 at 10:05 am - Permalink
In reply to You probably have picked the… by chozo
A is complex.
What is wrong is that if I do MatrixOp A x A and then powC(A,2) I get different answers.
powC(A,2) gives me the same result as typing A^2
A x A gives me the same result as MatrixMultiply A x A
For some reason powC and ^ are not doing the expected matrix multiplication.
November 2, 2022 at 11:53 am - Permalink
I see your point now. powC / powR does indeed seem to do only scalar multiplication. I have no idea if there is a command for proper repeated matrix multiplication. Maybe someone else knows. By the way, I find a factor of 50000 also a bit extreme. What is your use case here?
November 2, 2022 at 07:04 pm - Permalink
Here is a snippet of a working example using MatrixEigenV. A caveat is that I have tested it only with a small Hermitian matrix. The example uses a power of 8 for demonstration. Note the use of powC( ) on the eigenvalues. (IP 8.04, Win10). In principle, after diagonalization, the entire power operation could be written in one MatrixOP line.
November 3, 2022 at 08:59 am - Permalink
In reply to A is complex. What is wrong… by sleepingawake86
s.r.chinn posted the proper way to calculate the power.
Powc() PowR() work on (matrix) element-by-element basis. This is NOT matrix multiplication. Try, for example:
November 3, 2022 at 09:32 am - Permalink
It seems to me that one plausible scenario for expanding to a power of 50000 is that the matrix is unitary. Then the magnitude of the determinant must equal 1, and each eigenvalue is of the form exp( i lambda), also magnitude 1. This type of matrix can be thought of as a generalized rotation. If the matrix is not unitary, I don't see how numeric overflow or underflow can be avoided for arbitrarily large powers.
November 5, 2022 at 06:30 am - Permalink
This is actually a hard task, numerically. There is a classic article on this, "Nineteen Dubious Ways to Compute the Exponential of a Matrix, Twenty-Five Years Later" by Cleve Moler and Charles Van Loan. (Moler was a creator of Matlab.)
See https://epubs.siam.org/doi/abs/10.1137/S00361445024180
November 9, 2022 at 05:41 pm - Permalink
