Referencing built-in CurveFit functions
I am sure I have seen the answer to this question before, but I cannot seem to turn it up:
Can I call the built-in CurveFit functions (eg. gauss, hillequation, etc) to generate values in a wave? Eg I'm looking for something like
wave w
wave coefficients
w=hillequation(coefficients,x)
though obviously that doesn't work.
As far as I know, this is not possible. But for some functions an equivalent command is available. For example, in case of Gaussian you can call
You can fake this however, by calling CurveFit with the 'only guess' option (/O) and a prepared coefficient wave. This, however, involves a graph for creating the output. You are better off with recreating the function in question (e.g., HillEquation) in most cases.
November 24, 2022 at 03:34 pm - Permalink
In reply to As far as I know, this is… by chozo
tonyIf you use the curve fitting dialog to perform a fit using settings that generate a fit wave, you can find in the history the assignment used to set the values of the fit wave from parameter values in w_coef. You can use this same assignment to generate values.
For a HillEquation fit you have:
November 25, 2022 at 04:38 am - Permalink
