Move a cursor (in a subwindow) using a hook
Hi, I am trying to update a value in a SetVariable object whenever I move a cursor in a graph (similar to the Cursor Moved Hook Demo), except that this time the graph is a subwindow in a panel and I cannot find the way to make it work. Do you have any suggestions? Thank you.
tony
Note that graph subwindows don't have their own hook functions, you have a set a hook for the parent window to monitor for the cursor moved event. Maybe that is part of the problem?
JimProuty
Here's a modified Cursor Moved Hook example that hooks a subwindow
#pragma rtGlobals=3	// Use modern global access method.
Macro DemoSubWindowHook()
	Make/O/N=(10) xx=p*1000
	Make/O/N=(10) yy=sin(p/4)
	Make/O/T/N=(10) text="text for point "+num2istr(p)
	ExampleSubGraph()
Window ExampleSubGraph() : Graph
	Display /W=(69,49.25,699.75,444.5)/K=1  as "Graph with Subwindow"
	ShowInfo
	TextBox/C/N=readout/A=LT/X=1.66/Y=2.05 "\\JCMove the Cursor: the point number is shown here"
	ControlBar 40
	SetVariable xValue,pos={56.00,9.00},size={90.00,18.00},bodyWidth=80,title="X"
	SetVariable xValue,value=xx[0]
	SetVariable textValue,pos={174.00,9.00},size={144.00,18.00},bodyWidth=120
	SetVariable textValue,title="Text",limits={-inf,inf,0},value=text[0],noedit=1
	Display/W=(0.1,0.1,0.9,0.9)/HOST=#  yy vs xx
	ModifyGraph wbRGB=(65535,65534,49151),frameStyle=1, mode=4,marker=19
	Cursor/P A yy 0
	RenameWindow #,G0
	SetActiveSubwindow ##
	SetWindow kwTopWin,hook(myHook)=newCursorMovedHook
EndMacro
Function newCursorMovedHook(s)
	STRUCT WMWinHookStruct &s
	Variable statusCode= 0
	strswitch( s.eventName )
		case "cursormoved":
			// see "Members of WMWinHookStruct Used with cursormoved Code"
			NewUpdateControls(s.winName, s.traceName, s.cursorName, s.pointNumber)
			break
	endswitch
	return statusCode
Function NewUpdateControls(graphName, traceName, cursorName, pointNumber)
	String graphName	//"ExampleSubGraph#G0"
	String traceName, cursorName
	Variable pointNumber
	WAVE xx=root:xx
	WAVE/T text=root:text
	String hostGraph= StringFromList(0,graphName,"#") // removes #G0
	SetVariable xValue,win=$hostGraph,value= xx[pointNumber]
	SetVariable textValue,win=$hostGraph,value= text[pointNumber]
	// I don't use wx and wy, but you might
	Wave/Z wy= TraceNameToWaveRef(graphName,traceName)
	Wave/Z wx= XWaveRefFromTrace(graphName,traceName)
	TextBox/W=$hostGraph/C/N=readout "point number = "+num2istr(pointNumber)
	Print "Y value= ", wy[pointNumber]
