Counting the number of atoms for an element in a chemical formula
I have a 2D wave wherein column 1 is a list of chemical formulas and column 2 is their intensity in a soft ionization mass spectra. Now I want to calculate elemental ratios for each of these formulas (e.g. O:C, N:C, H:C and S:C ratios). For this, I am trying to figure out a way for the program to read numbers between text.
For example: C6H10O5. I want the program to be able to figure out how many C, H and O atoms are in this formula. Kindly advise how to optimally do this. I was trying to use regex expressions but couldn't iron out the logic.
The issue is that in some formulas there will be double digits for an element while a single digit in others (e.g. C6 vs C16). So, the program needs to be able to recognize when it encounters a text as opposed to a number while counting for an element.
How could I best execute this task?
Thanks a ton!
Best regards,
Peeyush
chozo
For your simple case, I constructed this and it seems to work, i.e., the function extracts the number behind the species letter:
Function countAtoms(String formula, String species)
	if (strsearch(formula, species,0,2) == -1)
	String count
	SplitString/E=(".*"+species+"([[:digit:]]+).*") formula, count
	return str2num(count)
For example:
print countAtoms("C6H10O5","H")
  10
In reply to by chozo
KurtB
You might need to deal with the case of no digit(s) after the element.
I was working on the following when the replies were posted:
Function getElmntCount(sElmnt, sChem)
	string sElmnt
	string sChem
	string sRegEx = "([" + sElmnt + "]{1})([[:digit:]]+){1}"
	variable vCount = 0
	string sDummy, sCount
	if( GrepString( sChem, sRegEx )  )
		SplitString /E=sRegEx sChem, sDummy, sCount
		vCount = str2num( sCount )
		sRegEx = "([" + sElmnt + "]{1})"
		if ( GrepString(sChem, sRegEx) == 1 )
			vCount = 1
	return vCount
Function getCHONC(sChem)
	string sChem
	variable vC, vH, vO, vN, vS
	 vC = getElmntCount("C", sChem)
	 vH = getElmntCount("H", sChem)
	 vO = getElmntCount("O", sChem)
	 vN = getElmntCount("N", sChem)
	 vS = getElmntCount("S", sChem)
	printf "C: %g, H: %g, O: %g, N: %g, S: %g\r", vC, vH, vO, vN, vS
Peeyush Khare
Thank you so much, tony, chozo and KurtB for these awesome suggestions! I am going to try them out and let you know in case I'm still stuck. Really appreciate the help!
olelytken
I would probably search through the string one character at a time.
1. The first character should be upper case
2. Check if the next character is lower case, numeric or upper case
3. Save lower case, if present
4. Save numeric, if present
5. Once you reach a new upper case character you start from 1
At the end you probably want to check the letter combinations against a list of valid elements
tony
function/S elementlist(string formula)
	string strList = ""
	string strCount, element
	variable vCount, vAtoms
	if (GrepString(formula, "^[A-Za-z0-9\.]+$") == 0)
		return ""
	do
		SplitString/E=("(^[A-Z][a-z]*)([[:digit:],\.]*)(.*)") formula, element, strCount, formula
		if (strlen(element))
			vCount = NumberByKey(element, strList)
			vCount = numtype(vCount) ? 0 : vCount
			vAtoms = str2num(strCount)
			vAtoms = numtype(vAtoms) ? 1 : vAtoms
			strList = ReplaceNumberByKey(element, strList, vCount + vAtoms)
			return ""
	while (strlen(formula))
	return strList
Peeyush Khare
Thanks all again for your excellent solutions!
@tony: thanks! Upon running elementlist ("C6H10O5"), I get C:6; H:10;O:5; as a text solution which is great. However, I want to store the counts in specific numeric waves so I could calculate the O:C, N:C, S:C ratios etc.
One quick issue is that the output from elementlist will have or miss elements depending on which ones are present in the chemical formula. So how to assign element counts to individual numeric waves for each element?
For example, I have a 1D wave with chemical formulas. Now I want 5 other 1D waves (or lets say 1 2D wave with 5 columns) where each column stores numeric count values of C, H, O, N, S. When an element is not present in the formula, it gets assigned a value of NaN in the 2D wave. I think if I start with a fully NaNed 2D wave, that will take care of the assigning NaNs to absent elements. However, I still need to assign the result from the text output as numeric values in individual columns of the 2D wave.
Actually I haven't used "Numberbykey" much before so this is quite a learning experience for me. Not sure how to extract numbers from your code and assign them to 1D waves..
Kindly advise (all). Thanks a ton!
tony
If you want to use the keylist approach you can extract values from the list using the NumberByKey function. So you could put the keylists in a textwave and then write something like Wave2D[][%C] = NumberByKey("C", ListWave). But, if you're working with waves, you may be better off with chozo's approach: Wave2D[][%C] = countAtoms(FormulaWave, "C").
If the columns have elements as dimension labels you can also write
Wave2D = countAtoms(FormulaWave[p], GetDimLabel(Wave2D, 1, q))
Edit: I mixed up the names of the functions by chozo and KurtB
chozo
If you will choose my code, rather use the revised function below, which can also count single atoms:
    String countStr
    SplitString/E=(".*"+species+"([[:digit:]]+).*") formula, countStr
    Variable count = str2num(countStr)
    return numtype(count) == 0 ? count : 1
print countAtoms("H2O","O")
  1
tony
And, for completeness, there's this horribly inefficient version:
Wave2D = NumberByKey(GetDimLabel(Wave2D, 1, q), elementlist(FormulaWave[p]))
Peeyush Khare
Thanks a lot, tony and chozo, for your responses. Below is what I have set up based on your codes, which does the job. I am going to read up more on the NumberbyKey function:
Function elements(specieswave)
wave/t specieswave
variable i,j,num = dimsize(specieswave,0)
dfref dfr=root:Parameters:
svar/sdfr=dfr elements
variable ecount = itemsinlist(elements)
make/d/o/n=(num,ecount)elementscount = nan
make/d/o/n=(num,ecount-1)elementsratios = nan
for(i=0;i<ecount;i+=1)
SetDimLabel 1,i,$stringfromlist(i,elements),elementscount
for(i=1;i<ecount;i+=1)
SetDimLabel 1,i-1,$stringfromlist(i,elements)+"/C",elementsratios
for(j=0;j<ecount;j+=1)
for(i=0;i<num;i+=1)
elementscount[i][%$stringfromlist(j,elements)] = countAtoms(specieswave[i],stringfromlist(j,elements))
for(j=1;j<ecount;j+=1)
elementsratios[][%$stringfromlist(j,elements)+"/C"] = elementscount[p][%$stringfromlist(j,elements)]/elementscount[p][0]
elementsratios = numtype(elementsratios) == 1 ? nan : elementsratios
edit elementsratios
edit elementscount
tony
Note that you can use an implicit loop rather than nested loops to set values in a wave:
// use this
elementscount = countAtoms(specieswave[p],stringfromlist(q,elements))
// instead of this
   for(i=0;i<num;i+=1)
