How to call a Macro inside a function
Here is a Macro that I wrote. Inside this Macro, It calls another macro named loadODMRtrace. But I would like to change this Macro into a Function, so that I could type the function in the commend window to load traces. I am wondering if there is anyway to modify this code, so that I could have a Function loadODMRtraces(pathname), and call the Macro loadODMRtrace inside the function. See the details of coding below. Much appreciated!
Macro loadODMRtraces(pathname)
// calls loadtrace on all files in folder called pathname
// Load and process all files in a given folder.
// The folder is specified by pathName which becomes a dialog
// if no input is given.
// YOU MUST INCLUDE #include <Strings as Lists>
// SOMEWHERE IN YOUR PROCEDURE, AS THIS MACRO
// CALLS SUBROUTINES FROM THAT INCLUDE FILE.
String pathName // name of symbolic path or "" to get dialog
variable/d numfiles
String filename
PauseUpdate; Silent 1 // Processing files . . .
Variable index=0
variable/d tracenum
if (strlen(pathName)==0) // if no path specified, create one
NewPath/O temporaryPath // this will put up a dialog
pathName = "temporaryPath"
print IndexedFile($pathName,-1,"????")
do
fileName = IndexedFile($pathName, index, ".csv")
if (strlen(fileName)==0)
break // break out of loop
// Assume file name is of form mmddyyc.xxxx, where x is a number. Strip off the number.
tracenum = str2num(filename[7,10])
loadODMRtrace(tracenum,filename,pathname)
print index,filename,tracenum
index += 1
while(1)
if (Exists("temporaryPath")) // kill temp path if it exists
KillPath temporaryPath
EndMacro
Have a look at the Execute operation, this can be used to call macros from functions.
August 19, 2024 at 01:05 pm - Permalink
When you post Igor code, please follow the instructions in this posting:
https://www.wavemetrics.com/forum/general/formatting-code-forum-posts
August 19, 2024 at 04:45 pm - Permalink
Macros are ancient and should be avoided in most circumstances. Use functions instead.
In the case of the macro above, to convert it to a function, all you need to do is change "Macro" to "Function" and remove the PauseUpdate line. You don't have to but I would change "EndMacro" to "End".
If you do this, you will also need to change the loadODMRtrace subroutine to a function.
For further discussion, execute this:
DisplayHelpTopic "Converting Macros To Functions"
August 20, 2024 at 09:55 am - Permalink
