make an image from regular array of x values, and 2D waves for Y and Z
I am taking data by sweeping one (X) parameter from xmin to xmax with step xstep; then for each value of x I sweep Y from a min to a max that differ for all Xs, the step remaining the same. I acquire the Z value for each (X,Y). I would like to make an image from this dataset, without any interpolation.
The pixels are therefore all the same size in X and Y, but their edges are not necessarily aligned.
Here is an example of dataset:
X={1,2}
Y={{0,1,2},{0.2,1.2}}
Z={{0,2,3},{1,4}}
In this example, I want to obtain an image with square, 1x1 pixels, centered at {1,0}, {1,1}, {1,2}, {2,0.2}, {2,1.2} with colors corresponding to the Z wave: 0, 2, 3, 1, 4 (see attached image, horribly drawn in powerpoint)
I did not find a way to do it, can somebody help me?
Seems like you would need to make an image using a matrix that covers the entire rectangular region of your "pixels" with many cells per "pixel". The a complicate multidimensional wave assignment could be devised to fill that matrix with the appropriate Z value depending on the X and Y values from your matrix's X and Y scaling. Fill in NaN for the cells that are outside any of your "pixels"
After some thought, the fill of the matrix is going to be difficult...
1) It would be best to have X and Y waves that give the boundaries of the rectangles involved, i.e. `make xwave = {.5, 1.5, 2.5}`
2) Since the number of cells in the Y direction is inconsistent, you will need a separate wave for each X range. Likewise, you probably need a separate Z wave for each X range.
3) Once you have 1) and 2) in order, some code will be required to look up the appropriate Z value.
To simplify, I can relax the constraint of having Y values than lead to shifted pixels. Let us assume that all Y values are integers, for example.
No need- here is some code:
Function fillimage(Wave xw, Wave/WAVE ywaves, Wave/WAVE zwaves, Wave imagewave)
	imagewave = lookupZvalue(x, y, xw, ywaves, zwaves)
Function lookupZvalue(Variable xx, Variable yy, Wave xw, Wave/WAVE ywaves, Wave/WAVE zwaves)
	Variable xindex = BinarySearch(xw, xx)
	if (xindex < 0 || xindex >= numpnts(xw)-1)
		return NaN
	Wave yw = ywaves[xindex]
	Wave zw = zwaves[xindex]
	Variable yindex = BinarySearch(yw, yy)
	if (yindex < 0 || yindex >= numpnts(yw)-1)
		return NaN
	return zw[yindex]
Here are commands that make waves that match your data above:
•make Xwave = {.5, 1.5, 2.5}
•make YWave1 = {-.5, .5, 1.5, 2.5}
•make ywave2 = {-.3, .7, 1.7}
•make zwave1 = {0,2,3}
•make zwave2 = {1,4}
•Make/N=2/WAVE ywaves = {ywave1, ywave2}
•make/N=2/WAVE zwaves = {zwave1, zwave2}
And a command to make the output image wave (probably you will have more than two y and z waves, so you will need to write some code/commands to make the image wave):
•make/N=(100,100) imagew
•setscale/I x .5, 2.5, imagew
•setscale/I y -.5, 2.5, imagew
And, finally, the command to invoke the code:
fillimage(xwave, ywaves, zwaves, imagew)
A recreation macro for an image display using the image wave created above:
Window Graph0() : Graph
	Display /W=(766.5,154.25,1161,362.75)
	AppendImage imagew
	ModifyImage imagew ctab= {*,*,Rainbow256,0}
	ModifyGraph mirror=0
EndMacro
I'd propose this approach.
* Create code to draw a box that is 1 wide by 1 tall with fill rgb color.
* Create code to put a box at a centered point (x, y).
* Iterate over the (x, y) coordinates, calling the box code to center the box at each (x, y) with the given rgb/grayscale color.
This is not an image, it is a set of graphic boxes.
I'd suggest also trying to put square markers of size N at the (x, y) positions, increasing N until the pixels just touch. Then, use an f(z) wave to set the grayscale or color of each marker. Again, not an image, instead a set of neighboring square boxes.
Could you make similar display as regular cartesian graph by using square markers and f(z) color from the Z values?
You have bunch of Z values, each with its own x and y. Create waves for Zvalues, Xvalues, and Yvalues. As you collect the data, for each Z value store it in Zwave and store also X and Y values in their waves. This creates simple triplet of waves with the data. Plot Ywave vs Xwave and use Zwave as color wave. I tried with marker square (marker=16) and with some playing with size it looked reasonable.
In reply to by johnweeks
Excellent, Johnweeks! Exactly what I wanted, and written in a compact, elegant code. I am really greatful, thank you for taking the time to answer me and writing the full macro. I also learn in the way you write the procedure, I never used this wave/wave, and I would not have come to the idea of filling the imagewave in a single line by writing it simply as a function of x,y. Thank you!
Thank you also to jjweimer and ilavsky for their clever suggestions, which would also work, but I like to fabricate an image that I can easily modify (color scales, zooms, etc.) with all the image tools.
