retrieve name of current experiment
Does anybody know how to retrieve the name (and possibly the path) of the current experiment?
A
ChrLie
IgorInfo(1)
returns the name of the current experiment ... not sure about the path, though..
Christian
aclight
ChrLie wrote:
IgorInfo(1)
If you've saved the experiment already, Igor creates a path named "home" which points to the directory in which the experiment resides. So you can use PathInfo to see if the home path exists, and if it does then use the S_path output variable.
jamie
Dr. Jamie Boyd, Ph.D.
UBC In Vivo Imaging Core
If the experiment has been saved, the path will be saved in the path "home"
pathinfo home
print S_Path
