returns the name of the current experiment ... not sure about the path, though..[/quote]
If you've saved the experiment already, Igor creates a path named "home" which points to the directory in which the experiment resides. So you can use PathInfo to see if the home path exists, and if it does then use the S_path output variable.
Christian
September 16, 2010 at 06:58 am - Permalink
September 16, 2010 at 08:32 am - Permalink
Thanks anyway.
September 16, 2010 at 09:11 am - Permalink
UBC In Vivo Imaging Core
If the experiment has been saved, the path will be saved in the path "home"
September 17, 2010 at 12:47 pm - Permalink
