Wave reference
Function AverageNephData()
SETDataFolder root:working
Variable avgTime
Prompt avgtime,"Enter Averaging Time in Minutes"
Doprompt "Data Averaging Time",avgTime
String VariPrefix = num2str(AvgTime)+"_Min_avg"//, noisevari
variable a,b,c,d
//Print avgTime, VariPrefix
//Sets up wave lists
Wave Neph_450_STP
Wave Corr_450,Corr_550,Corr_700,Neph_D8Time //These are 5 second data
Make/T/O/N=3 source={"Corr_450","Corr_550","Corr_700"}
Make/T/O/N=3 result={"Corr_450","Corr_550","Corr_700"}
Make/T/O/N=3 noise={"Corr_450_stdev","Corr_550_stdev","Corr_700_stdev"}
	//Makes wave names: attaches averaging prefix to the beginning of the wave name
	FOR(a=0;a<3; a+=1)
		result[a] = variPrefix+"_"+source[a]
		noise[a] = variPrefix+"_"+noise[a]
	ENDFOR
//	MAke/O/D/N=3 localwaveavg, localwavesdev
	Print source[0]
variable pointer, Min1, Min2
string timestring1,minute1,timestring2,minute2	//averging window starttime, startminute, averaging window endtime, endminute
Make/D/O/N=(numpnts(Neph_D8Time)/(12*Avgtime)) WinStart, WinEnd	//These are the start and ending indices for each averaging win\ow
Make/T/O/N=(numpnts(Neph_D8Time)) NephTimeString	//This will hold the D8Time wave as a string
NephTimeString = secs2Time(Neph_D8Time,1)	//Converts time, in seconds, to a string time format
	c=0; d=0			//c holds the window start index as fixed. d increments and then the average is taken from the c and indices
Make/D/O/N=(numpnts(Neph_D8Time)/(12*avgtime)) AveragedTime //Creates the time wave for the averaged data
	FOR(pointer=0;pointer<(numpnts(result));pointer+=1)
		Wave localwaveavg = $result[pointer]
		Wave localwavesdev = $noise[pointer]
		FOR(b=0;b<(numpnts(neph_D8Time));b+=1)			//Loops through the length of the Neph_D8Time wave
			Timestring1 = NephTimeString[c]; Timestring2 = NephTimeString[b]
			Minute1 = TimeString1[2,3]; Minute2 = TimeString2[2,3]
			Min1 = str2num(Minute1); Min2 = str2num(Minute2)
			IF(Min1+avgtime == Min2 || Min1+avgtime == Min2+60) 		//Will execute when the minutes are different by the amount of the averaging time
				Wavestats/Q/R=[c,b] $source[pointer]					//The OR part of the IF covers the time when the minutes go from 59 back to 0.
				localwaveavg[d]=v_avg
				localwavesdev[d]=v_sdev
				AveragedTime[d] = Neph_D8Time[c]
				d+=1
				//IF(Timestring2 - Timestring1 > 10*avgtime)
				//ENDIF
			c=b		//This sets the index to the beginning of the next averaging window
			ENDIF
		ENDFOR
	ENDFOR
END
The reference to localwaveavg or localwavesdev are not being creating using the list from $result[pointer] and noise[pointer]. I've used this technique in other code. I'm sure it's something simple that I'm missing. localwaveavg should be a named wave from the the list of waves in result. Any help would be greatly appreciated. Thanks.
ssmith@bnl.gov
jjweimer
Have you used the debugger to step through the code? You may need to do put the text content in ().
wave localwaveavg = $(result[pointer])
What happens when you use intermediate strings to assign the terms first?
string rstr = result[pointer]
string nstr = noise[pointer]
wave localwaveavg = $rstr
mavanspronsen
I don't think there is anything wrong with making the wave references from the text wave. The following code seems to work fine.
Function testwaveRef()
make/O/N=10 testw
testw=x*gnoise(2)
Make/O/T/N=1 textw
textw[0]="testw"
variable pointer=0
wave tw=$textw[pointer]
display tw
I did notice that in the line
The first parameter, Neph_D8Time, is a wave reference, while secs2Time() requires the first parameter to be a number. Maybe that hepls?
hrodstein
I suspect that the wave references are failing because the waves do not exist. Here is a simplified test that shows that the technique you are using works if the waves exist:
Function Test(int flag)  // Execute Test(0) then Test(1)
	if (flag == 0)
		KillWaves/Z Corr_450, Corr_550, Corr_700
		Make/O Corr_450, Corr_550, Corr_700
	int pointer
	for(pointer=0;pointer<(numpnts(result));pointer+=1)
		Wave/Z localwaveavg = $result[pointer]
		if (WaveExists(localwaveavg))
			Printf  "Wave %s exists\r", NameOfWave(localwaveavg)
			Printf "Wave %d does not exist\r", pointer
ssmith911
This is the error from the debugger:   error: WAVE reference to "localwaveavg" failed.  Adding () around the $[pointer]doesn't work.
ssmith911
I thought that these lines created the waves programmatically. I'm now thinking that is not the case. I'm trying to create waves that are programmatically named based on the the user input averaging time.
johnweeks
To create a new wave with a name contained in a string (in this case, element of a text wave) you need something like this:
Function test()
	WAVE/T result
	WAVE/T noise
	Variable pointer
	Variable npnts=10
	Make/D/N=(npnts) $(result[pointer])/WAVE=localwaveavg
	Make/D/N=(npnts) $(noise[pointer])/WAVE=localwavesdev
If you have a pre-existing wave that is a template for the waves you need to create, you can replace `Make/D/N=(npnts)` with `Duplicate`
