Moving a picture programmatically
I have a picture that I have pasted into a graph. Is there a way to move it programmatically? If I double-click on the picture and change its position in the dialog box, the picture moves and a command like
DrawPICT -1.32,47.5,1,1,PICT_1
is placed in the command window. If I enter DrawPict ...PICT_1 commands, with different positions, in the command window then my picture moves. But if I use a DrawPict command in a function, it seems to have no effect.
Is there a way to programmatically move a picture once it's in place?
Igor
A simple approach for implementing the moving a picture insert in a graph window is by drawing the picture into a subwindow (hosted in your graph) and then calling MoveSubWindow in your function.
HTH,
AG
jtigor
Often a doupdate operation needs to be called to effect a change to a graph.  Don't know what the rest of you code is like to predict if this will help.
johnweeks
The dialog works on a selected draw item. When the item is selected, then the command applies to that item.
Unfortunately, it's quite cumbersome to programmatically alter a particular draw object. Originally, you had to kill the content of the entire draw layer, and then re-draw everything with the amendments you want.
Now, you can do something that is more targeted, but still cumbersome. When you initially create the draw objects, make a "named group" using `SetDrawEnv gstart, name=MyPicture` (where MyPicture can be changed to your choice of name). Then when you want to change that object, use `DrawAction` to erase that group and then you can redraw just that group with amendments.
amtravco
In the end I erased the layer each time and redrew the object. This is fine for my purposes because I am making frames for a movie. So I draw the current frame, save it as an image file, draw the next one, save it, and so on. Once I have all the images in a folder on my computer, I use QuickTime to make them all into a movie.
But yes, it would be nice to be able to refer to draw items and change their properties programmatically.
