Igor 7 under Win 11?
Ralf Schmauder
Hallo,
I still run Igor 7 (update is applied for).
Does anyone know whether Igor7 will still work under Windows 11?
Thanks & Best regards,
Ralf
Hallo,
Ralf
As far as we know. Igor 7 was the first version using the Qt framework, and has quite a few bugs. We would recommend upgrading to Igor 9 if at all possible. You can download Igor 9 and try it for 30 days to find out if there are problems for your work.
February 11, 2025 at 10:14 am - Permalink
Thanks, Problem is to get the update through our adminsitration, budget is likely not available before April/May...Also I use a 32 bit extension (https://www.wavemetrics.com/project/bpc_ReadHeka), not sure if this works with Igor 9.
Still, the original Question remains: will Igor 7 work under Windows 11?
Best
Ralf
February 12, 2025 at 12:02 am - Permalink
Yes, it does. I just launched Igor 7.08 on my Windows 11 machine.
February 12, 2025 at 10:45 am - Permalink
bpc_ReadHeka works just fine under Igor 9 (32bit). I'm the author.
I'm not sure if (when) I will find the time to move it to 64bit.
--Holger
March 2, 2025 at 05:55 am - Permalink
