Open an email template
If you want to provide an easy way for someone to contact you, this snippet aims to open an email template in the system default email program.
To use the code in a help file - which may be useful for developers to collect feedback - you would insert an action and define the action helper as the procedure file containing the ComposeAnEmail() function.
function Demo()
NewPanel
Button button1,pos={10,10},size={20,15},title="",Picture=ProcGlobal#pMail, Proc=ButtonProc
Button button1,help={"Email the developer"}
function ButtonProc(STRUCT WMButtonAction &s) : ButtonControl
if (s.eventCode == 2) // mouseup
ComposeAnEmail()
function ComposeAnEmail([string user, string domain, string subject, string body])
domain = SelectString(ParamIsDefault(domain), domain, "uni-ingolstadt.de")
user = SelectString(ParamIsDefault(user), user, "victor.frankenstein")
subject = SelectString(ParamIsDefault(subject), subject, "Message from an Igor Pro user")
body = SelectString(ParamIsDefault(body), body, "Type your message here")
user = URLencode(user)
domain = URLencode(domain)
subject = URLencode(subject)
body = URLencode(body)
string cmd = ""
sprintf cmd, "mailto:%s@%s?subject=%s&body=%s" user, domain, subject, body
BrowseURL/Z cmd
return V_flag
// PNG: width= 198, height= 48
Picture pMail
ASCII85Begin
M,6r;%14!\!!!!.8Ou6I!!!#=!!!!Q#R18/!(p&k=TAF%&TgHDFAm*iFE_/6AH5;7DfQssEc39jTBQ
=U#;&M85u`*!mG5Nmir1#)n>FO/#6h#UA#F,q6:(,?!iI#lEYSod*Qq$@KU,Mh.,7X&l;B/R$c`uC#
XWF=hJfM_\:TX.;b+[C^qj#rIg<`,cbt$BeAV:SrIbT9(Q#>B5PfiDUIc)O&-0Lb3$a5e5hC.+rV@6
^0/&,k[^Wa9l-h$$ZA`TX$UG=:!)P;7!W9"9e'h6WLUj_Oo6Fpgein`uo_X&7//APB[9=85+oQk^&4
3%()H9]Gr0W(><)k65VL];q(IEYg?pGDp$2d"780!8uJ<W[&^lKf*V,Sq,TGqEDQN%B25dae7A=Cai
ZIpeg(rJ&srr)`aHF6qqa,_<N(rk(?V8J6OL,E4HeR2\ST<@KY)u'+$U$F`pR7mU9jBl)m(A@LsVmb
p&cC@fq4[!4hCFb]nE;I40UMN%V4ot^P;8hGP+TUH^jTVq@UXa)_G\Gs2eS7C9jmbor_o"iXDJfLUB
FS'X1`EX"6_i$7qCk7.ND?AR!9j1S\@fJ]i7Qf=MaaCS[9D5;gU!Q_]Y#6!:2<,dq=A7BH<bEn:tRu
_cR9`r/#"FqE-+.3aQ&pAB]H!=6rA']7hiqpiG_-R<ZTaO)tj`?<%9dcS5?"ZWL<X\;Q8=,E'iN\%d
TQ4(r3(Igt^]Cki`:;1i_/F*$$'Yk2p9Y`fNfhTW5#'>L[Vr:oLD:;9T:Z"oop48R,P,71oh5`RWKR
P0)e?n!-Qn,E'GG`?KG,[lD5)U5?c\'Jr\*_,2bM2dl^6_Vk_,ROI.Q.$i1Q(dKosZs#%$*$"a*JgL
ga3!sT`$3n;cEH#k.MFKm/[+fEtrh,nj1CfG^]=<Rrr52A_('+F&G!#2b_iCHn/Gb*Q-B'oD$?%^:$
t.R5/hScr3.`,Nd5f/kMMmCNPr+4LiSZ,sceL2S2NCcJX6anb<MH,m!tL@.T.C*IR)[Nk[o\<:21/R
b$CW)WE"r:_@2M6`35U?#-3tS2Ktgat#/J7;f:9a=6;`u_;:)BW#=ma&QA,FAAjXf..4UTTW#EQ'E,
ZMlM'jtWIrU-]puE,REGuVmMe=^DIrId^"cXT`3/Z8+;])SeK>W]nl<+f+^DqChnJ$^lRa<l#[9Ch\
S`9GCqmYncE^EX(eSo\T#1GCl3G(KbRO52@YF2RO)ND;ni.U+dqE!,KLiPV1@@AOgcHaG=ifPJmc"7
WHU&Z%h-km#k)?oHn;mY/1,Y8!QNIup/T?g`m^OQ:O\diltp@mQ+r.udTlodcuSOU;!7kU,qV,E]h#
7Ets;F)q%6bQg8i6X;4</lK`@X!#4\Qj#ec7o]^e!qVKb@,U=f<Ut-n30L_YkJjrF;bZ#&*&!k-'Lp
P31Ngl$"bNJZ/DQ]X.ec<S5;o1_(C[M'CAI?_f>IAV-m+6P<Hl1$5t935C`ZcBpp_M'>K"pH4pGk`K
<on!JFrb2%'SI'+T@0gmifP3;cJPU\g?dF)r"Erqq<i#d/>mMo*2hVJ2?#K$rD_oQn4@2CB3&=nX]?
E&beeeeVS!?`.3\PtH,J_$u9)q`&0<.G89.ispi3I/3>E]M8`(\Cr\"=fBBFUQ?a8-48[<cZ+D_52O
lVodhN:cd,mFURfM;nF5oYk_+<q'EGc.@)YhBk<4SbRCgLITr?T/F5>aHn)(m)IX[$SlZdl-"p"#Vl
p-kJm-O)sh7Im6hogJ>\(dKafcFX#'U,55Yhq5pT?f/iLIHM!hIEcG(CVrnfJ=KW!PnBTKp>)G/-Ec
t'Wg<qQES3=3&h=i>S!Z)e&9AMM5MbP;+"H_0`][8X(o$\:/4Q3),BsX!q<?&Hs#K)>f!']mdBKCG_
a/ZfQ#^&h0G$u0,.`Ij7"BO@71,"NLr2)J:`O9=?^Z?L_:%55B'!s"V&MW>T@0?&I"/\3224\L>uAu
9GgVr6/r-/.&3Ho3#9[ON,H+_j5]/jUS)&S3'KMq\(dIaDn"J\4:2uS*,b&GY-Ge+om/S\4iRBu4b1
qtihMB_L>pkBh?Eu8hr!Jdo[NGK]03i6&%B$WQ>KJf6,UQZH[GX%*S*4W8WlWBdt&p)q!d6p"\"rQg
raq&jgT0cnG;tg8WosB_`+!^UR99,Wr`#4I%tKl$3^F)^QNS*!K@"elFLlt3U!s/Zj*VM#mJ-43I%E
bBJu>jnq$91ctkUMrSVnNk:N%Dbhjtj\IP^eqr>^-hI?Q$?n`^\U(E941UVCaU*sP+(m%Xp'_np9]p
),863mU!#W;fO85*>XZqd=HI0bFd&-O08k,7-WNN/ui"G-:_s%e4X!WX&ILVtkTkdlepa2^+dUJ[$s
8LP8[OC]<_Cj+SNb2kC/Is%t+1ZB<6>dW*kh=EkH<Y\a%>gqO0!!!!j78?7R6=>B
ASCII85End
I haven't tested this much so I'd appreciate feedback on whether it works on various systems.
Works okay with Mac 11.7.9 (Big Sur) and Thunderbird.
You should be able to use BrowseURL instead of ExecuteScriptText. Inserting body text should be easy as well...just use something like
Each field (user, domain, subject, body) should likely be passed through URLEncode first. You are already encoding spaces in the subject but other non-ascii characters also need to be encoded.
IIRC, Gmail users will need to click a button in the location bar in order for mailto links to use Gmail.
February 23, 2024 at 01:19 pm - Permalink
Ah, thanks, I should have thought of that. BrowseURL makes it trivial.
February 24, 2024 at 01:26 am - Permalink
Works well on MS Windows 11 Home.
Neat!
March 25, 2025 at 08:39 pm - Permalink
