Can't update a control programmatically
Using the same panel from my previous question: https://www.wavemetrics.com/forum/general/how-poll-all-controls-when-interacting-any-control
I would like the "Probe 1 run" and "Probe 2 run" to update to either "1" or "n/a" depending on if there is data available for those probes. That is, it should default to the first replicate experiment wave if it exists, or display "n/a" and disable if it isn't.
Here's the code I've tried, which is nearly identical to the snippet for Probe 1:
string matchProbe2 = WaveList(prefix,";","") variable numProbe2Replicates = ItemsInList(matchProbe2, ";") if (numProbe2Replicates == 0) print "No Probe2 data found for this experiment." PopupMenu Probe2SelectPopup,win=smp0,value="n/a",disable=2,popvalue="n/a" wave z = root:Processing:InputData:Probe2Data z = 0 else String nry = makeValueString(numProbe2Replicates) PopupMenu Probe2SelectPopup,win=smp0,value=#nry,disable=0,popvalue="1" endif ControlUpdate/W=smp0 Probe2SelectPopup
This does not work. This disables or enables the popups just fine, but it does not set the display value. I don't so much care about displaying "n/a" when the popup is disabled, but it's pretty crucial that the popup revert to the first replicate if it exists, since that feeds forward into further processing.
I suggest that you probably must include a mode= setting in the popupmenu command.
May 1, 2025 at 09:40 am - Permalink
jjweimer is right- use the "mode=<one-based menu item number>" keyword to control what appears as selected in the menu. That implies that one of the menu items needs to be "n/a" to allow you to select that item. The presence of a "/" may cause trouble- it would be better to use "Not Applicable".
Another bit of advice: don't use the `popvalue` keyword. It was invented for a very specific purpose. In my experience, it only causes trouble. I think it was a misfeature invented to solve a non-problem. If you really want to know more detail, I can provide it :)
May 1, 2025 at 09:49 am - Permalink
Here is a short bit of code to do the change.
May 1, 2025 at 10:30 am - Permalink
