Igor Programming Tool (IPT) for formatting and linting your code
Current version: 0.9 - 2025-06-24
We (byte physics e.K.) wanted to share a tool which we developed over the last two years.
It is a command line application called ipt [1] which allows to format and lint Igor Pro procedure code. We are using it in production since more than a year.
The documentation has a nice example for the formatting feature at [2]. The linter has a lot of different rules, the most prominent one being FixOldStyleFunctionArgument [3] which converts from pre IP7 function parameter declarations to inline ones.
The tool is available for all major operating systems, with also winget and installer packages for Windows.
As you can imagine parsing Igor Pro procedure code can be tricky. So in order to get it out of the door this millenia, we maintain a list of known limitations [4]. If you find something in your code which is not in that list, but still should be supported according to our philosophy [5] we would like to hear from you, see [6].
We hope other Igor users find the tool helpful as well.
On behalf of all developers,
Thomas
[1]: https://docs.byte-physics.de/ipt/
[2]: https://docs.byte-physics.de/ipt/#feature-overview
[3]: https://docs.byte-physics.de/ipt/linter-rules.html#fix-old-style-functi…
[4]: https://docs.byte-physics.de/ipt/limitations.html
[5]: https://docs.byte-physics.de/ipt/philosophy.html
[6]: https://docs.byte-physics.de/ipt/contact.html
Thank you for this nice tool, which I already tried out.
I don't know whether it is OK to post feedback here, but a couple comments for now:
- First, I would like to note that ANSI escape code parsing is apparently switched off by default on windows which makes the output from this tool near unreadable. It took me quite some head-scratching to get this to work, but I followed this guide in the end:
https://stackoverflow.com/questions/51680709/colored-text-output-in-pow…
It would help to have a short tutorial for different command-line tools and / or an option to switch off formatted output (sorry if this already exists, but I couldn't find it)
- During installation, there is an option to create a desktop shortcut, but this does nothing apparently. I don't know what this would be useful for in any case since it is a command-line tool.
- Apparently, ipt lint and ipt lint -i shows different output for my files (the latter showing MUCH more warnings). I guess this is intended, but I don't get it. Does the -i flag include a setting for a more limited set of checks?
April 22, 2025 at 11:56 pm - Permalink
Totally fine for me.
We don't do any autodetection if ANSI escape codes are supported. You can use the `--color=no` switch to turn it off. I've made a note to document that. `ipt --help` has all the documentation for the top-level switches and `ipt <cmd> --help` for cmd.
I've made a note and will followup.
I'm suprised to hear that `ipt lint -i` shows more warnings. I would have expected the opposite as `-i` implies `--fix` which fixes linting warnings/errors instead of only warning. Do you have an MWE?
April 23, 2025 at 06:37 am - Permalink
Thank you for the quick reply. I meant that 'ipt lint -i' shows much less warnings than 'ipt lint'. But the file itself is never changed in either case, so I wonder what -i is for then. I'll attach a test file. With the latter command I get two warnings and with the former about 6 warnings as output. If I understand you correctly, some warnings do not appear because they are apparently fixed (without actually being fixed in my case). Note that the file is properly formatted and overwritten via ipt format -i.
Regarding the formatting, I personally am not so fond of (see also the testfile before formatting):
- inline comments getting 'unaligned'. I have usually an aligned column for comments with enough visual distance, which I find much easier to read than comments tacked directly behind code.
- tabs for panel control elements being replaced without aligning equal signs (pos={}, size={} etc.). I have panel code also heavily aligned to make the code easily readable.
- equal signs of #pragma not being aligned
The latter two I can 'fix' myself, e.g., by setting an IPT_FORMAT_OFF there. But I am not willing to go through all my hundred comments to realign them after formatting, so no use for this particular feature for me now. It would be great to have a switch for 'leave comment indentation alone'. (Yes, I am aware that this kind of commenting might be considered bad style, but I want comments to sit out of the way and not in-between actual code if I can avoid it).
April 23, 2025 at 07:22 am - Permalink
That's definilty odd. We'll have a look.
That's getting into the taste area. I actually prefer comments in their own lines instead of trailing comments. But that is not something ipt can fix. Now of course we could a flag to keep comments, but until now we tried very hard to not have any knobs for the formatter. The reason is that the complexity of testing and documentation explodes with knobs. A bad example is clang-format (formatter for C++) where you even have tools like https://clang-format-configurator.site/ to help with writing the config file.
We try to always use recreation macros where the macro code is stored in separate files. So I rarely look at GUI code like that. I'll make a note.
I need to think about this one.
April 23, 2025 at 08:05 am - Permalink
Hello, I am one of the developers of this tool. First of all, I appreciate your feedback.
I looked into the details. Apparently, if we have at least one warning or error for that specific file, nothing changes. We always try to have no warnings in our code, so this bug went unnoticed until now.
Interesting, because on my Windows it worked right out of the box, so I didn't think much about it. But I use the modern Windows Terminal and VS code all the time. We can update our documentation to highlight this problem. The solution is to add `--color=no` to your arguments.
April 23, 2025 at 08:40 am - Permalink
Thank you for the follow-up. Regarding the ANSI support, it may be that you have set everything up a long time ago to work with the terminal. I can have a look at another PC, but it initially didn't work ... neither with the terminal nor with Powershell both in ver. 5.1 or 7.5. I just tested it, and color=no works under these circumstances at least.
Another small thing: When there is a warning about a switch statement, the parser seems to include either the \r or \n or something else in the output. See the attached image.
April 23, 2025 at 06:30 pm - Permalink
In case a line termination (\r, \n or \r\n) is part of the code with error, we print a replacement character ⏎ [1] to the output. This is only visible if Windows is setup to use Unicode, which is unfortunately not the default and requires administrative changes [2]. I'll create an internal issue, so we can fix this and add some documentation.
[1]: https://www.compart.com/en/unicode/U+23CE
[2]: https://superuser.com/a/1435645
April 24, 2025 at 02:12 am - Permalink
We fixed the ipt lint -i part. It may report some errors that cannot be fixed automatically, but it will always write the changes to the output file.
We also aligned the #pragmas at the top of the file.
To get the new ipt, download the latest release from our website. There is no update on winget yet.
May 27, 2025 at 06:22 am - Permalink
Thank you for the update. Two comments from my side:
- I wonder how the list of warnings for linting is sorted. It seems to be roughly based on line number but not completely (sometimes it shows errors on a much earlier line before increasing again)?
- The ReadabilityMissingParenthesis warning produces two lines of output, one of them only the word 'here'; see the attachment.
May 27, 2025 at 07:58 am - Permalink
This order depends on certain conditions but is always deterministic. It is primarily influenced by the line numbers, though each rule that creates these warnings can also affect it. We have not added any logic to sort them by line. (Maybe we will.)
That's an interesting regression and the output should be different. I will look into it tomorrow.
May 27, 2025 at 08:51 am - Permalink
This has been fixed and the newest ipt version (only available at our website) will create a correct error log.
The order of the errors is kept, but if you think a special one is needed, just write to me. I can also add a longer description to the documentation that explains the order.
June 10, 2025 at 05:53 am - Permalink
Thank you for the update. The linter seems to output identical messages multiple times in some cases. See the attached files. I also think I have seen a case where there is no line break in-between two warning outputs (i.e., the messages are directly stitched together and the alignment is all off), but I can't seem to reproduce it at the moment.
Otherwise it works fine for me and I have already updated all my code to produce no warnings with the linter (while switching off three rules I personally do not want to follow strictly).
June 19, 2025 at 01:35 am - Permalink
Max is already looking into that.
Nice to hear that the linter works for you. Out of curiosity can you share which linter rules you have disabled?
June 20, 2025 at 05:08 am - Permalink
Sure, I disable:
While this is no error, I don't want to use rtFunctionErrors=1. I am working completely alone on about 10 projects, and already debugging the usual code is a monumental task. I simply cannot afford to look for all these edge cases. The manual is very vague anyway about which errors to expect here.
While I see the point, I don't want to follow this rule after all. For one, I often initialize the variables upon creating them and think having this on separate lines is a waste of space:
Maybe it could be an exception to the rule that there is no warning if a string is followed by [= ""] only and a variable is followed by [= 0]. This would not discourage such initialization of variables.
Also, there are occasions where combining statements is better for readability (imho):
Yes, I could also spend 9 rows for above code, and maybe I will do that some day. Who knows...
Initially, I also switched off BugproneMissingSwitchDefaultClause, but in the end I decided to follow the rule, even if that meant just inserting many empty 'default' statements into the code.
June 20, 2025 at 05:51 am - Permalink
We are currently in the final stages before the next release, which will include a fix for the duplicate log lines that you reported.
This issue was caused by a minor bug in the rule's internal state machine, which caused the rule to match multiple times.
June 23, 2025 at 02:39 am - Permalink
Thank you for the new version. I am playing around with the formatting lately. While I find most changes helpful, it would be great if there was a list of formatting rules and an --exclude flag for switching some of the off. As mentioned earlier, I don't find it helpful that formatting is messing with my tabbing for alignment, especially for panel code and inline comments. I could work with IPT_FORMAT_OFF in some cases, but having an exclude list would be even better.
Also, I found some possible contradiction in the coding conventions. Wouldn't the following recommendation trigger a ReadabilityElseAfterReturn warning:
June 27, 2025 at 09:24 am - Permalink
Hi Stephan, thanks for trying out the latest version.
Currently, there is no option to turn on or of certain formatting "rules" or to configure them. In fact there is no formatting "rule" at all. We read the whole Igor source file into an abstract syntax tree (AST) [1]. You can imagine this, as a tree for which each node is some part of the original source code. Any original formatting is lost at this time. Later we print this AST using our own rules.
Linting works a bit different to printing. We have a set of state machines [2], that operate on the given AST and searches for specific patterns. Later is some code executed on found patterns and the AST might be transformed. A linting rule is just a name of a state machine, which can be enabled or disabled.
Our printing do not have any configuration for now, because this adds to the complexity of the process. I cannot tell you if and when we will add formatting configurations. We have a large list of issues we have to fix or features we want to add. If you think a formatting configuration is really important for you, you might write us an email using the contacts listed above.
Thanks for reporting this inconsistency, we will fix this.
[1]: https://en.wikipedia.org/wiki/Abstract_syntax_tree
[2]: https://en.wikipedia.org/wiki/Finite-state_machine
June 27, 2025 at 12:23 pm - Permalink
I see. Thank you for the explanation.
Something else (sorry for being picky): It seems that the formatter enforces that brackets immediately follow branch statements (if, elseif etc.) and loops (for, while) without any space. I am not sure that this improves readability. It seems that most of these statements also have a space character in front of the bracket in the official manual (yet, at least for the for-loop the examples are inconsistent). I would vote for introducing a space character here or are there any good reasons for not having one?
June 27, 2025 at 07:03 pm - Permalink
A few more comments:
- I find the manual somewhat confusing regarding what every ipt command is doing exactly, i.e., which checks are applied and which things are changed under which circumstances. For example, I was under the impression that 'ipt lint --fix' only fixes issues as defined by the linting rules, but instead all formatting of 'ipt format' is applied as well.
- I find it confusing that there are different commands for different task in some cases (format, check) and a flag in other cases (lint with and without --fix). Maybe the manual could be a bit clearer about what each command does: maybe have a table listing what is checked, what are the rules, is formatting / fixing applied, and is the file itself modified or just the result printed in the output. I personally would find it clearer if there was only 'format' and 'check' with, e.g., a '--strict' flag to indicate that the linting rules are observed as well. But, of course, this is just to give you and idea what might be difficult to follow for me.
- The manual is a bit lax with the usage of 'errors', which seems to include 'warnings' in some cases (e.g., for linting). As I understand it, if there are errors then the linter will only display these and no warnings. And 'ipt check' will of course display no linter warnings. Maybe the manual could be adjusted to make this distinction?
- The 'Special features' category seems to apply to 'ipt format' and 'ipt lint --fix', right? Wouldn't it be better to name it 'Formatting features' then?
- Finally, is there a way to output results for rules with severity 'none' (and possibly 'info' if there are new rules in the future)? Otherwise these rules are a not very useful if formatting is avoided.
June 30, 2025 at 10:50 am - Permalink
Sorry to spam this thread yet again. In the last two weeks I was working long hours to make all my code adhere to the linting rules but one (CodeStyleDefaultPragmas). This really was an odyssey, but anyway: Do you or anybody else know what adhering to the last rule actually entails, i.e., having rtFunctionErrors on? Is this only about str2num() or are there many more? I am hesitant to comb through my 25000 lines of code again if I am not even sure what to look for...
July 3, 2025 at 07:02 pm - Permalink
Sorry for the late reply.
This is now tracked in https://github.com/byte-physics/igor-pro-coding-conventions/issues/47.
The linter rules you disable:
> what to look for...
I could not find a list of functions respecting that in the manual. str2num and SelectString are some functions I know about. Yes it can be challenging to adapt to his rule, especially without tests.
> ReadabilityOneLineVariableInitialization
You don't have to initialize variables to zero, this is always done by IP. Initializing strings to empty string misses the places where you accidentally read from it before writing into it. In a code base of 170k lines of IP code we have 140 places where we declare and initialize strings to "". The reasons are:
- Building up a list of strings via AddListItem or concatenating
- Potentially build a string via sprintf/etc. in a loop/if/switch statement where you don't know if it is executed
I've made a note so that we look into teaching IPT to find superfluous initialization. Basically it would check that there needs to be the possibility of a read before a write. That will be tricky so don't hold your breath.
We are getting close to taste, but using our conventions and constants I would write it as:
yes this takes more lines. The goal of the linting rule is to avoid having too much information in one line.
This and the related CodeStyleFallthroughCaseRequireComment is a source of constant bugs for us, that's why these exist.
> find it helpful that formatting is messing with my tabbing for alignment, especially for panel code and inline comments. I could > work with IPT_FORMAT_OFF in some cases, but having an exclude list would be even better.
The choice of formatting is heavily opionated and by design without options to change. I can surely understand that this conflicts with habits from IP power users like you. Even if we would allow formatting options, we just can't afford them effort-wise. We are also much more inclined to invest into linters.
No need to be sorry. We are discussing formatting and linters ;)
The reason is that I personally don't like how it's done in the IP manual. I also only look at IP code with syntax highlightning turned on and think that the different colors for the statement and the parantheses `()` help in distinguishing both enough.
I've made a note regarding the manual inconsistencies and we'll tackle that for the next version.
Here are some explanations:
Yes this comes at a suprise as it is not mentioned. We'll fix that.
This only applies to the formatter, so yes this is misnamed.
Good idea. I think it would be useful as well to output the linter rules in a compact table with the Rule name/Fixable/Severity/Features columns. I've made a note.
July 6, 2025 at 01:00 pm - Permalink
Thomas, thank you very much for your detailed answer. I am looking forward to future updates of this tool. As mentioned, I have now implemented all linter rules which give a warning other than CodeStyleDefaultPragmas, despite rejecting some of the rules initially. This has helped to weed out bad style and improved readability as a whole. I am also moving towards implementing more of the formatting rules (manually), even if I surely will not follow all of them and probably will not make use of the automatic formatting. In the end, even if I release a few projects here I doubt many people will read my code, so it is mostly for myself and for future-proofing (i.e., remember what the code does). :-)
Another idea / possible feature: While working on removing issues,I would have found it useful if the check / lint commands state the number of found errors and warnings per type, e.g., ...
July 6, 2025 at 11:54 pm - Permalink
Great!
July 7, 2025 at 03:12 am - Permalink
I would like to test this. I cannot however get the standalone macOS version to do anything. I double click on it and nothing happens. I see the package contents has the Unix Executable ipt file. Double clicking this gives this as the opening
I copied the executable to /usr/local/bin and can see it in the terminal via which ipt. Trying to run ipt from the terminal gives zsh: killed ipt as the outcome. Trying ipt -h as a test gives about the same result.
What am I missing?
July 13, 2025 at 01:46 pm - Permalink
Jeffrey: Thanks for the report.
I did here:
What MacOSX version are you on?
Here I'm on:
This is a universal binary for x64/aarch64.
You would normally use it something like `ipt format <someIPFile>` and after ensuring you have backups you would do `ipt format --inplace <someIPFile> `.
July 13, 2025 at 02:14 pm - Permalink
I downloaded straight from the Website. The app went to downloads and unzipped. I am on macOS 15.5 on an intel MBP.
I sent a crash log to the Byte-Physics support email. Perhaps we should correspond directly that way until we iron out the issues.
July 13, 2025 at 02:28 pm - Permalink
