VulkanCompute - run GPU compute shaders on your waves
Hi all,
I'd like to share an experimental XOP, VulkanCompute, that lets you run a GLSL compute shader on the GPU using Vulkan, with Igor waves as the GPU buffers and Igor scalars as push constants. It's handy when you have a heavy, highly parallel per-element calculation and want to offload it to the GPU.
A demo procedure and full help file are included in the attached zip.
What it does
- You write a small GLSL compute shader as an Igor string.
- Input/output waves are bound as
std430storage buffers (SSBOs):/INwaves first, then/OUTwaves, all in descriptor set 0. - Scalars are passed through a push-constant wave (
/PC), marshaled as floats. - Results are copied straight back into your output wave.
You don't need to be a GLSL expert. In practice the easiest way to get a shader is to start from one of the provided examples and tweak it, or to ask an AI assistant (ChatGPT, Claude, Copilot, etc.) to generate the GLSL for your calculation - just tell it the binding convention above (/IN waves at bindings 0..N-1, /OUT waves next, scalars in the push-constant block as floats). Paste the result into an Igor string and go.
Two operations
VulkanCompute- compile-and-run a GLSL shader on the GPU.VulkanCompileShader- precompile a shader once to a SPIR-V wave, then reuse it viaVulkanCompute /SPV=...to skip the per-call compile.
Quick example (waveC = varA*waveA*waveB + varB):
The demo .ipf goes further, with a compute-bound example (a per-element transcendental loop) that shows a real GPU speedup, plus a precompile-and-reuse example. To see it in action, just run one of these two functions from the command line:
DemoGPUvs1CoreAndMultiCoreCPU()- times the same heavy calculation on the GPU, on a single CPU core, and on all CPU cores viaMultiThread, and prints the timings side by side.DemoGPUPrecompiledVsMultiCoreCPU()- same comparison, but the shader is precompiled once withVulkanCompileShaderso the GPU timing reflects only the dispatch, not the one-time compile.
A word on performance: the GPU is not a magic "make it faster" button. For simple element-wise math (like the example above), MatrixOp/FastOp on the CPU are typically faster, because the calculation is memory-bandwidth bound and the cost is dominated by moving data to and from the GPU. VulkanCompute pays off when the per-element work is heavy (many operations per value) or when you run many kernels over resident data.
Requirements / installation
- Igor Pro 10 (64-bit), Windows only. This build targets Igor Pro 10 and is not available for macOS.
- A Vulkan-capable GPU driver (recent NVIDIA/AMD/Intel drivers already include the Vulkan runtime
vulkan-1.dll). No Vulkan SDK is needed. - Igor loads only XOPs whose file name ends in
64.xop, so the file must be named VulkanCompute64.xop. Put it (or a shortcut to it) in anIgor Extensions (64-bit)folder and relaunch Igor. Drop the.ihfhelp file next to it.
Notes / caveats
- Computation is fp32 by default. Double precision (
/DBL) works only if your GPU reports theshaderFloat64feature. - Waves named in
/INand/OUTare resolved in the current data folder. - This is an early, main-thread-only build for Igor Pro 10 on Windows - feedback welcome. It is Windows only; a macOS version (via MoltenVK) is not built.
Attached: VulkanCompute.xop, VulkanCompute.ihf, and VulkanCompute_Demo.ipf.
Give it a try and let me know what performance you see on your hardware.
AG
My benchmarks are encouraging, especially when precompiling the shader:
This is for an Intel i9-13900K (3.00 GHz) CPU with an RTX 3070 Ti (8 GB) GPU
July 27, 2026 at 09:39 am - Permalink
Even though XOP wasn't written for macOS, I wanted to see if Igor 10 could use this XOP on an M4 with Crossover. It seems to be working:
July 27, 2026 at 11:25 pm - Permalink
On my 4-year-old Windows machine featuring an Intel Core i9-12900K processor and NVIDIA GeForce RTX 3090 graphics card:
•DemoGPUvs1CoreAndMultiCoreCPU()
n=200000, iters=2000, threads=24
GPU = 152.1 ms
CPU 1-core = 23277.4 ms (153.1x slower than GPU)
CPU N-core = 1556.6 ms (10.2x slower than GPU, 15.0x faster than 1-core)
MSE GPU vs CPU = 2.15023e-12, MSE MT vs 1-core = 0
•DemoGPUPrecompiledVsMultiCoreCPU()
n=200000, iters=2000, threads=24 (GPU time excludes one-time compile)
GPU (precompiled) = 9.4 ms
CPU N-core= 1547.1 ms (164.8x slower than GPU)
MSE GPU vs N-core CPU = 2.15023e-12
Even after leveraging all 24 CPU threads, the GPU is still over 10× faster. Once the GPU kernel is precompiled, the ratio grows to ~165×, while maintaining essentially identical numerical results. Keep in mind that most CPU computations ran in DP while the GPU ran in SP.
July 28, 2026 at 02:32 pm - Permalink
I also have a Windows ARM laptop with this hardware, so it's running Igor 10 under emulation via Prism.
It nearly choked on the single core CPU stress test, with the GPU coming to the rescue:
July 28, 2026 at 04:46 pm - Permalink
