VulkanCompute - run GPU compute shaders on your waves
Hi all,
I'd like to share an experimental XOP, VulkanCompute, that lets you run a GLSL compute shader on the GPU using Vulkan, with Igor waves as the GPU buffers and Igor scalars as push constants. It's handy when you have a heavy, highly parallel per-element calculation and want to offload it to the GPU.
A demo procedure and full help file are included in the attached zip.
What it does
  • You write a small GLSL compute shader as an Igor string.
  • Input/output waves are bound as std430 storage buffers (SSBOs): /IN waves first, then /OUT waves, all in descriptor set 0.
  • Scalars are passed through a push-constant wave (/PC), marshaled as floats.
  • Results are copied straight back into your output wave.
You don't need to be a GLSL expert. In practice the easiest way to get a shader is to start from one of the provided examples and tweak it, or to ask an AI assistant (ChatGPT, Claude, Copilot, etc.) to generate the GLSL for your calculation - just tell it the binding convention above (/IN waves at bindings 0..N-1, /OUT waves next, scalars in the push-constant block as floats). Paste the result into an Igor string and go.
Two operations
  • VulkanCompute - compile-and-run a GLSL shader on the GPU.
  • VulkanCompileShader - precompile a shader once to a SPIR-V wave, then reuse it via VulkanCompute /SPV=... to skip the per-call compile.
Quick example (waveC = varA*waveA*waveB + varB):
The demo .ipf goes further, with a compute-bound example (a per-element transcendental loop) that shows a real GPU speedup, plus a precompile-and-reuse example. To see it in action, just run one of these two functions from the command line:
  • DemoGPUvs1CoreAndMultiCoreCPU() - times the same heavy calculation on the GPU, on a single CPU core, and on all CPU cores via MultiThread, and prints the timings side by side.
  • DemoGPUPrecompiledVsMultiCoreCPU() - same comparison, but the shader is precompiled once with VulkanCompileShader so the GPU timing reflects only the dispatch, not the one-time compile.
A word on performance: the GPU is not a magic "make it faster" button. For simple element-wise math (like the example above), MatrixOp/FastOp on the CPU are typically faster, because the calculation is memory-bandwidth bound and the cost is dominated by moving data to and from the GPU. VulkanCompute pays off when the per-element work is heavy (many operations per value) or when you run many kernels over resident data.
Requirements / installation
  • Igor Pro 10 (64-bit), Windows only. This build targets Igor Pro 10 and is not available for macOS.
  • A Vulkan-capable GPU driver (recent NVIDIA/AMD/Intel drivers already include the Vulkan runtime vulkan-1.dll). No Vulkan SDK is needed.
  • Igor loads only XOPs whose file name ends in 64.xop, so the file must be named VulkanCompute64.xop. Put it (or a shortcut to it) in an Igor Extensions (64-bit) folder and relaunch Igor. Drop the .ihf help file next to it.
Notes / caveats
  • Computation is fp32 by default. Double precision (/DBL) works only if your GPU reports the shaderFloat64 feature.
  • Waves named in /IN and /OUT are resolved in the current data folder.
  • This is an early, main-thread-only build for Igor Pro 10 on Windows - feedback welcome. It is Windows only; a macOS version (via MoltenVK) is not built.
Attached: VulkanCompute.xop, VulkanCompute.ihf, and VulkanCompute_Demo.ipf.
Give it a try and let me know what performance you see on your hardware.
AG
VulkanComputePackage.zip (1.75 MB)
Ben Murphy-Baum
My benchmarks are encouraging, especially when precompiling the shader:
•DemoGPUvs1CoreAndMultiCoreCPU()
  n=200000, iters=2000, threads=32
    GPU        =    366.6 ms
    CPU 1-core =  20815.3 ms  (56.8x slower than GPU)
    CPU N-core =   1074.9 ms  (2.9x slower than GPU, 19.4x faster than 1-core)
    MSE GPU vs CPU = 2.15023e-12,  MSE MT vs 1-core = 0
•DemoGPUPrecompiledVsMultiCoreCPU()
  n=200000, iters=2000, threads=32  (GPU time excludes one-time compile)
    GPU (precompiled) =     12.8 ms
    CPU N-core        =   1030.1 ms  (80.3x slower than GPU)
    MSE GPU vs N-core CPU = 2.15023e-12
This is for an Intel i9-13900K (3.00 GHz) CPU with an RTX 3070 Ti (8 GB) GPU
ggermer
Even though XOP wasn't written for macOS, I wanted to see if Igor 10 could use this XOP on an M4 with Crossover. It seems to be working:
  n=200000, iters=2000, threads=10
    GPU        =     88.5 ms
    CPU 1-core =  33312.0 ms  (376.3x slower than GPU)
    CPU N-core =   4766.7 ms  (53.9x slower than GPU, 7.0x faster than 1-core)
    MSE GPU vs CPU = 2.30319e-12,  MSE MT vs 1-core = 0
 n=200000, iters=2000, threads=10  (GPU time excludes one-time compile)
   GPU (precompiled) =     10.6 ms
   CPU N-core        =   4695.9 ms  (444.0x slower than GPU)
   MSE GPU vs N-core CPU = 2.30319e-12
Igor
On my 4-year-old Windows machine featuring an Intel Core i9-12900K processor and NVIDIA GeForce RTX 3090 graphics card:
 n=200000, iters=2000, threads=24
   GPU        =    152.1 ms
   CPU 1-core =  23277.4 ms  (153.1x slower than GPU)
   CPU N-core =   1556.6 ms  (10.2x slower than GPU, 15.0x faster than 1-core)
 n=200000, iters=2000, threads=24  (GPU time excludes one-time compile)
   GPU (precompiled) =      9.4 ms
   CPU N-core=   1547.1 ms  (164.8x slower than GPU)
Even after leveraging all 24 CPU threads, the GPU is still over 10× faster. Once the GPU kernel is precompiled, the ratio grows to ~165×, while maintaining essentially identical numerical results.   Keep in mind that most CPU computations ran in DP while the GPU ran in SP.
Ben Murphy-Baum
I also have a Windows ARM laptop with this hardware, so it's running Igor 10 under emulation via Prism.
Snapdragon(R) X 12-core X1E80100 @ 3.40 GHz CPU
Qualcomm(R) Adreno(TM) X1-85 GPU
It nearly choked on the single core CPU stress test, with the GPU coming to the rescue:
  n=200000, iters=2000, threads=12
    GPU        =    143.2 ms
    CPU 1-core = 110566.6 ms  (771.9x slower than GPU)
    CPU N-core =   7968.1 ms  (55.6x slower than GPU, 13.9x faster than 1-core)
    MSE GPU vs CPU = 2.16207e-12,  MSE MT vs 1-core = 0
  n=200000, iters=2000, threads=12  (GPU time excludes one-time compile)
    GPU (precompiled) =     14.6 ms
    CPU N-core        =   7891.9 ms  (540.9x slower than GPU)
    MSE GPU vs N-core CPU = 2.16207e-12
pawel.wzietek
Your comparison CPU-GPU seems unfair to me: for CPU you are using Igor code, not a C code like for the shader.
Did you try to make comparisons with OpenCL code (via OpenCL XOP) ?  I often use this XOP so I can compile exactly the same C code for GPU and CPU.  For heavy single-thread calculations on CPU  I installed the Intel's OpenCL framework, where the compiler apparently does a lot of aggressive optimizations (partial loop unwiding for multicore CPU's etc.), I did not study the details but for my apps the OpenCL code is in general a lot faster than any Igor code.   I might prepare a demo/benchmark if anybody is interested.
Igor
Hello Pawel,
I agree that the comparison is not perfect. A better comparison would have been an XOP that computes the result in C using a single thread. However, considering that a typical user is more likely to implement the operation using Igor instructions rather than write a custom XOP just for a multiplication, I believe the comparison I provided is still useful.
I did not explore OpenCL because I was looking for a more general and modern solution. OpenCL does have at least one advantage that comes to mind, but it is not supported as broadly. Then again, given NVIDIA's trajectory over the past year or so, one could argue that platform portability may become less of a concern in the future.
AG
pawel.wzietek
Hello AG,
I  was curious so I wrote an OpenCL code equivalent to your Heavy_GLSL function, here is what I obtain on my i7-12700 (12 physical cores):
  Igor loop (your CPUCompute_Heavy function):  24520.4 ms
  Igor multithread (your MTCPUCompute_Heavy function) :  1937.4 ms
 OpenCL (your Heavy_GLSL function) , single thread :  279.2 ms
 OpenCL, 12 threads :  76 ms
I attach my  experiment below.
Interestingly, running the same code on my RTX3060 I obtain :
OpenCL GPU, single thread :  34815.8 ms
 OpenCL GPU, 4000 threads :  12.3 ms
Pawel
CLcomputeDemo_CPU.pxp (1.57 MB)
Igor
Hi Pawel,
Thanks for providing these performance numbers.
It is amazing how much work can be done by 3800 cores.  Although it is getting more difficult (and expensive) to get the high end graphics cards, they clearly outperform the CPUs and most of the built-in graphics hardware available these days.
AG
pawel.wzietek
True for SP,  but in DP the CPU often wins (unless you buy a special compute-grade GPU ?).   On my RTX there is at least a factor of 10 slow down in DP.
aclight
FWIW the nightly build of Igor 10 now takes about 7% less time to execute the CPU-1 core part of DemoGPUvs1CoreAndMultiCoreCPU due to some loop optimizations I just merged. For simpler wave assignments (think "wave1=x") the decrease is closer to 40%. The CPU-N core part is also likely a little faster though I haven't measured that configuration and the difference may not be measurable.
