contour fill colors
I'm trying to create a contour plot with a color fill. This is for Igor 9 on mac, so if this is an Igor 9 bug I'm out of luck. I first create contours with linear interpolation. The contour line colors and fill are taken from the same color table. All looks correct:
In the plot the contours are an overlay for an image plot, and the color table is cold hot with transparency. The data set is rather sparse, so I prefer to use 4x interpolation. With ModifyContour ... interpolate=1 the contours are updated as I expect, but the color fill now doesn't match the contour colors:
These are the contours that I want, but why doesn't the fill color match the contour line color? This is, the blue colors at the start of my color table are used for the lower-numbered contour lines, but the color fill doesn't match anymore. Ideas?
I find that if I change the values to be contoured by subtracting or adding 2 to the dataset, the fill looks correct. Weird. This is what the plot should look like:
November 27, 2026 at 05:40 am - Permalink
