Find Big Waves
RGerkin
Mon, 08/02/2010 - 09:09 am
// Returns the name of any waves exceeding 'minSize' points wherever they are found in any directory.
Function FindBigWaves(minSize[,df,depth,noShow])
Variable minSize // A minimum number of points, e.g. 100000
variable depth // Used by the function recursion. Ignore.
variable noShow // Don't show the table at the end.
dfref df // A folder to use as the top level of the search. Default is root:
if(paramisdefault(df))
dfref df=root:
if(depth==0)
NewDataFolder /O root:Packages
NewDataFolder /O root:Packages:FindBigWaves
dfref packageDF=root:Packages:FindBigWaves
Make /o/T/n=0 packageDF:names
Make /o/n=0 packageDF:sizes
variable i
wave /T/sdfr=packageDF names
wave /sdfr=packageDF sizes
variable points=numpnts(names)
for(i=0;i<CountObjectsDFR(df,1);i+=1)
wave w=df:$getindexedobjnamedfr(df,1,i)
if(numpnts(w)>minSize)
names[points]={GetWavesDataFolder(w,2)}
sizes[points]={numpnts(w)}
points+=1
i=0
Do
string folder=GetIndexedObjNamedfr(df,4,i)
if(strlen(folder))
dfref subDF=df:$folder
FindBigWaves(minSize,df=subDF,depth=depth+1)
break
i+=1
While(1)
if(depth==0)
sort /R sizes,sizes,names
if(!noShow)
if(wintype("BigWaves"))
dowindow /f BigWaves
edit /K=1 /N=BigWaves names,sizes as "Big Waves"
dfref df=root:
if(depth==0)
variable i
points+=1
i=0
Do
if(strlen(folder))
break
i+=1
While(1)
if(depth==0)
if(!noShow)
August 29, 2010 at 10:26 pm - Permalink
dfref df=root:
if(depth==0)
variable i
sizes[points]={sizeOfWave(w)}
points+=1
i=0
Do
if(strlen(folder))
break
i+=1
While(1)
if(depth==0)
if(!noShow)
// posted by Howard in the forums
Function sizeOfType(inType)
Variable inType
Variable size=1
if(inType & 0x01)
size*=2
if(inType & 0x02)
size*=4
elseif(inType & 0x04)
size*=8
elseif(inType & 0x10)
size*=2
elseif(inType & 0x20)
size*=4
elseif(inType==0)
size=nan
return size
//My addition to account for multidimensional waves
Function SizeOfWave(w)
wave w
variable index, wavesize
wavesize =1
For(index=0;index<wavedims(w);index +=1)
wavesize *=DimSize(w,index)
wavesize *=sizeOfType(wavetype(w))
return wavesize
December 18, 2010 at 02:01 pm - Permalink
Your snipped includes this function:
wave w
wavesize =1
return wavesize
This can be rewritten as:
wave w
wavesize =numpnts(w) * sizeOfType(wavetype(w))
return wavesize
Also, note that this will not really work for text waves, data folder reference waves, or wave reference waves. Each point of a text wave can take up a different number of bytes, depending on the length of the string that is stored in that point. You could call strlen() on each point of a text wave to get a pretty good estimate of the number of bytes the wave will take up. The SizeOfWave function also doesn't account for the size of the wave's header, but every wave header is the same size and is usually relatively small compared to the size of the wave's data.
December 20, 2010 at 02:33 pm - Permalink
I also changed the first parameter to mean size in MB instead of number of points.
/// Modified from RGerkin's and hegedus code.
Function FindBigWaves(minSizeInMB[,df,depth,noShow])
Variable minSizeInMB // Minimum size in MB, e.g. 100
dfref df=root:
if(depth==0)
variable i
variable size = sizeOfWave(w)
if(size > minSizeInMB)
sizes[points]={size}
points+=1
i=0
Do
if(strlen(folder))
FindBigWaves(minSizeInMB,df=subDF,depth=depth+1)
break
i+=1
While(1)
if(depth==0)
if(!noShow)
Function SizeOfWave(wv)
wave/Z wv
variable i, numEntries
variable total = NumberByKey("SIZEINBYTES", WaveInfo(wv, 0))
if(WaveType(wv, 1) == 4)
WAVE/WAVE temp = wv
numEntries = numpnts(wv)
for(i = 0; i < numEntries; i += 1)
WAVE/Z elem = temp[i]
if(!WaveExists(elem))
continue
total += SizeOfWave(elem)
return total / 1024 / 1024
May 10, 2018 at 04:21 am - Permalink
