Loading an entire directory
Is there anyway instead of loading one file at a time and then having it do these steps, for it to load an entire directory, taking each file through these steps before it moves to the next file in the directory?
Function CCNLoader()
// Loads one file at a time, edits time wave, adds them to the proper waves, then deletes them
    do
        LoadWave/J/D/A=wave/K=0/L={4,6,0,0,0}
        if (V_flag == 0)        // Break if user hit the cancel button.
            break
        GetFileFolderInfo/Z S_path+S_fileName
        if( V_Flag == 0 && V_isFile )   // file exists
        wave wave0            // changes time data -> Time and Date data
        wave0=X
        wave0+=V_modificationDate
        Concatenate/NP {wave0}, TimeAll
        Concatenate/NP {wave1}, CurrentSSAll
        KillWaves wave0,wave1
        if (wAVEExists (wave48))   //check command history to see if there were alarms
            Killwaves wave48
            print "ALARM!!!"
            print "No Alarms"
    while(1)
Files are recorded like this every hour
CCN data YYMMDDhhmmss.csv
CCN data 080601125425.csv
CCN data 080601135426.csv
CCN data 080601145427.csv
astrotool wrote: Is there anyway instead of loading one file at a time and then having it do these steps, for it to load an entire directory, taking each file through these steps before it moves to the next file in the directory?
I don't understand your question. But I think the answer to your question is no. As far as I know, there's not really a way in any programming environment to load an entire directory at once, because directories are a collection of files and therefore each file must be loaded individually.
Maybe I'm not understanding your question.
Consider that you have two functions ...
Function/S LoadMyFile(theFile)
   string theFile
   <load the file>
   return (string list of waves loaded or "" if no waves loaded)
Function DoMyOperation(ListofWaves)
   string ListofWaves
   <do what you need to do on each wave(s) in the string list itsWaves>
You can do one of the following:
Function DoItAll_A(theList)
    string theList
    // theList = a string listing of the full path to all files in a certain directory
    // LOOP ON (load + operate)
    for (ic=0;ic<nt;ic+=1)
       sprintf theFldr, "root:MyFolder%d", ic
       NewDataFolder/O/S $theFldr
       theFile = StringFromList(ic,theList)
       itsWaves = LoadMyFile(theFile)
       if (strlen(itsWaves)==0)
          break
       DoMyOperation(itsWaves)
Function DoItAll_B(theList)
    string theList
   // LOOP ON (load)
          break
   // LOOP ON (operate)
      sprintf theFldr, "root:Myfolder%d", ic
      SetDataFolder $theFldr
      itsWaves = WaveList("*",";","")
Yes. Execute this to see the relevant help:
DisplayHelpTopic "Loading All of the Files in a Folder"
