include wave data with procedure file
I am working on a procedure file which will calculate electric field strength as it passes through a stack of various materials. To accurately determine the electric field as a function of wavelength, I wish to use the irradiance values from the AM1.5 solar spectrum. As I can not be certain that individual users will always use the same source for these values, I want to include these irradiance values with the procedure code. I can't just calculate these values at run-time as they do not follow an equation.
Is it possible to permanently store wave data as part of the procedure file? Or do I have to write a function which will fill the wave with constants?
You can create a wave in a function like this:
I used a free wave in this example but you could use a regular wave.
If the wave may be too big to conveniently generate in code, you can store it in an Igor binary wave file in the same folder as the procedure file. Then use the FunctionPath function to get the path to the folder containing the binary wave file and use LoadWave to load it into memory.
October 28, 2011 at 08:01 am - Permalink
Do a search on the work "packages" in the general help search and follow the first link that says "Using a Package Data Folder".
October 28, 2011 at 08:07 am - Permalink
I understand that this is an option, but my wave would have over 4000 datapoints, accompanied by a corresponding x-wave, I was hoping there would be a better way.
October 28, 2011 at 08:16 am - Permalink
Sorry for my incompetence, but I was unable to find the above mentioned link when searching for "packages" or even searching for " package data folder". Could you please elaborate, or provide a link?
October 28, 2011 at 08:32 am - Permalink
Read the rest of my answer above about FunctionPath.
October 28, 2011 at 08:49 am - Permalink
Apologies ... I forgot the exact way to get this information ...
On the command line, type displayhelptopic "Using a Package Data Folder"
October 28, 2011 at 10:00 am - Permalink
